NEW DJI Go App + Firmware 1.3.20
12
25190 72 2015-8-3
jhall651
I just got done updating everything and I can tell you if flies even better!  I was having no issues really with the 1.2.6 other than a few lost signal but this one works flawlessly!  Not to mention I am getting much better range!  Anyone else experiencing that?
2015-8-4
mdazel
Flight distance : 1140725 ft
Ulysse Posted at 2015-8-4 15:52
Not only the FW cant be downloaded but unable to sync the flights in the user center (fail after 3%) ...
Hello there,
you need to update with the device you fly with and all should work well...on the log issu...mark your flights as favorites and sync again that should do it...!!! ;-)
2015-8-4
CaveDrone
Flight distance : 11549 ft
CaveDrone Posted at 2015-8-5 06:00
My new Avatar reflects..... WHAT!  New FIRMWARE!  Awesome
Quick question,  I am using Android,  ...
Nevermind,  found the answer after copious searching on the millions of threads on firmware updating,
Yes you can update the controller and phantom and fly on android  with out the new "soon to be released" android app.
  I did and it flew with no problem at all. Then again I was among the lucky gang who didn't problems previously except for the tilted horizon
2015-8-4
mdazel
mpdigiman Posted at 2015-8-4 15:59
Nice........ the release note say 'The firmware can be downgraded to 1.1.9' so we can go back to a s ...
Hello there,
I keep all my firmware past and present on the micro sim card...in the bird...dir structure as follows from the root inward...new folder I call mine...firmware...new folder the next one I name ...old_updates...new folders that I name...per versions...I put a copy of all my successful updates in there own folder....that includes the new version that I just upgraded to today...all files including the auto generated text files per upgrade...I can run any version I need or want...just-say-in...I leave a copy of all files to the version I am running on the root for the hard ware...aircraft...RC...barriers...to access as I use them...and to keep the RC and aircraft happy...Remember that this is how I fly and if you try this on your equipment it is at your own risk...as there are some that have told me that it can`t work and that you must fly with only the bin file on a freshly formatted sim card...!!! ;-)
2015-8-4
mdazel
REBELimgs Posted at 2015-8-4 16:38
We definitely don't need numerous threads on this topic.
hello there ,
What we don`t need is YOU THINKING that YOU have the right to tell anyone in this thread or any thread what they can or can not do... now that`s two comments in this thread that have nothing to do with the subject and you where complaining because we are just ALL very excited about the upgrade and talking about it...Just-Say-In
2015-8-4
mdazel
Hello there,
I was wrong you are just one of those that tell everybody what there are doing wrong and then do it... now that is 4 comments completely off topic...YOU ARE NOT HELPING...and I am not telling you can or can`t do it...just-say-in ...!!! ;-)
2015-8-4
mdazel
jpvalery Posted at 2015-8-4 22:05
Hey everyone,
Can we use the DJI Go with an older firmware ?
Hello there,
You would be entering a TEST scenario for sure trying that I would think...so if you are looking for stability stick with what is working now or change to what the codex has to offer in that complete container or package...That is only my opinion with a theme of being helpful to my fellow pilot...!!! ;-)
2015-8-4
mdazel
Adamation Posted at 2015-8-5 01:40
Since Updating my P3P to the latest firmware along with the remote the Android DJI App no longer mak ...
Hello there,
Start fresh...format your microsd card...read then follow the new release notes step by step if you did not the first time...,if you did more info please...!!! ;-)
2015-8-4
mdazel
Adamation Posted at 2015-8-5 05:49
Issue resolved after restarting everything  - Adam
Hello there,
GREAT NEWS...!!! ;-)
2015-8-4
venomx15301
jhall651 Posted at 2015-8-5 08:29
Yes you do. He does not know what he's talking about. It updates it to 1.3.20
One guy posted a support email that said B RC's do not need this FW update.
A bunch of people on another forum are posting they can not get their B RC's to update.
2015-8-4
REBELimgs
Flight distance : 46483 ft
mdazel Posted at 2015-8-5 09:28
hello there ,
What we don`t need is YOU THINKING that YOU have the right to tell anyone in this t ...
Yeah I'm going to some moron who said "JUST-SAY-IN" What does that even mean.  Someone posted two of the same threads in addition to the numerous others on the same topic and you attempt to scold me in some juvenile fashion. Go figure...
2015-8-4
jag 101
Yup same here vps issue resolved good job dji now I finally turn in vps and it works good.hopefully other pilot will have no issue.
2015-8-4
Vtran.records
I can't get my RC to update. I've tried updating via direct usb, through the app, and through the gimbal via micro usb.
I'm also not sure if my aircraft updated correctly. It spat out the following txt file below. I deleted the txt file and it generated the same file. Why would it say it the microSD has the same/older firmware as P3X_FW_V01.02.0006.bin, when the card only has P3X_FW_V01.03.0020.bin?
Result: Success.
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: P3X_FW_V01.02.0006.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Result: Abort.
========== 2015.06.25 18:34:23 =====================
Result: Abort.
========== 2015.06.25 17:46:10 =====================
Result: Abort.
Result: Abort.
========== 2015.07.03 21:01:05 =====================
Result: Abort.
========== 2014.01.01 00:00:13 remo-con disconnect======
Result: Abort.
========== 2015.07.04 18:35:29 =====================
Result: Abort.
========== 2015.07.04 18:42:49 =====================
Result: Abort.
========== 2015.07.04 23:51:32 =====================
Result: Abort.
========== 2015.07.04 23:53:27 =====================
Result: Abort.
========== 2015.07.12 18:48:57 =====================
Result: Abort.
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2015.07.12 23:03:56 =====================
Result: Abort.
Result: Abort.
Result: Abort.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.03.0020.bin
Upgrading ...
Result: Success.
========== 2015.08.04 22:21:01 =====================
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
2015-8-4
sploodge
Flight distance : 809350 ft
Vtran.records@g Posted at 2015-8-5 12:28
I can't get my RC to update. I've tried updating via direct usb, through the app, and through the gi ...
Format the card, place the firmware on it and try again.. Also when it completes post the log from the hidden /MISC/LOG folder also.
2015-8-4
rayrokni
Flight distance : 8139875 ft
mdazel Posted at 2015-8-5 09:22
Hello there,
I keep all my firmware past and present on the micro sim card...in the bird...dir st ...
what you are doing is just fine as long as all your fw binfiles are in folders and not in root directory. the only fw bin file that should be in root directory is the one you want to use and update to!!
2015-8-4
darylhunter75
any news on when android users will get the new Go pilot app.
thanks
2015-8-4
Amber
darylhunter75 Posted at 2015-8-5 14:51
thanks
Just had an email this morning from DJI Support saying that it will be released in the near future, does not say day, weeks or months!
2015-8-4
vladimirbogovci
Flight distance : 420 ft
Croatia
Hl all
I have problems with update.
I interrupted new version update at the time when they are not of the light lamp to drone.
After that I wanted to restart update but the sound of the battery is running wild and nothing happens.
Is there a possibility to reset the drone?
Need help please
2015-8-5
sploodge
vladimirbogovci Posted at 2015-8-5 16:07
Hl all
I interrupted new version update at the time when they are not o ...
Mmmm.. First off, for others, NEVER INTERRUPT THE FIRMWARE UPDATE! It can take 20-25 minutes and during this time will go through various cycles and light sequences ( and no lights ). I posted a video showing the complete cycle..
As for the problem now... When you say the battery makes a noise when you try again, if this AFTER powering everything off?
What you can try is format the SD card and put the firmware on it again and try the update again. If it still does not work, try the same thing with another battery if you have one.
2015-8-5
aburkefl
Flight distance : 78612 ft
Silly me. I went to sleep last night. Woke up this morning to gobs of mis-information and no Android update. Back to bed. LOL
2015-8-5
vladimirbogovci
Croatia
sploodge Posted at 2015-8-5 18:13
Mmmm.. First off, for others, NEVER INTERRUPT THE FIRMWARE UPDATE! It can take 20-25 minutes and d ...
Ty for info
Bet another battery and format the SD and now is working. Successfully installed new update.
Thanks a lot!!!!
Vladimir
2015-8-5
katolystic
Philippines
I made a quick video on how to update your Phantom 3 and the RC. It may be useful to newbies. Hope this helps.
Here is the link to the thread: DJI Forum Thread
2015-8-5
quasimodo
Malaysia
yes! at last...but since im an android user app go not out yet....can i update firmware 1.3.20 on my drone first? can my pilot app response to new firmware?
2015-8-5
chrisclaydon
Ok... No android app on the web site... so if u just got a New PH3, how do u get the android app??
2015-8-5
FantomDK
Denmark
I'm still holding back a little bit on 119 untill I've read up on experiences etc.
2015-8-6
Vtran.records
Hey Everyone,
I was able to update my RC. What I did was reformat my USB drive as FAT32 (it was exFAT before) and the update finally went through. I know the instructions say exFAT works, but try FAT32 too. Hopefully this helps someone else out.
PS. I love the new update! so many new features in the Go app. This s a huge improvement over the previous app.
2015-8-6
devin.Bhattacha
Flight distance : 1276224 ft
Same question as quasimodo: since the android app of DJI GO isn't available yet...does anyone know if firmware 1.3.20 will work with the DJI Pilot app on android? Is it OK to upgrade Phantom 3 Pro to 1.3.20 or should we wait until DJI Go is available for android?
Thanks!
2015-8-7
kgjamison
Flight distance : 460751 ft
Nt
Question. I updated the P3P, remote and batteries with NO trouble! Calibrated the IMU, gimbal, compass. But, I start the RC calibration and it never finishes. Tried an iPad and my iPhone. Won't finish the calibration. I can kill the app and relaunch and it flys great. Any idea why I can't calibrate the RC? I am going to do the Inspire tomorrow and home it goes just as smoothly.
2015-8-7
lostinthezone
Flight distance : 56732 ft
devin.Bhattacha Posted at 2015-8-8 12:36
Same question as quasimodo: since the android app of DJI GO isn't available yet...does anyone know i ...
I believe it's compatible.  I looked at an IPAD Air 2 today and was tempted for about 10 seconds..  I just can't stand to buy anything apple, let alone spending $600+ for a new tablet just for my P3.  I hope the android version is released soon and performance is better.
Rob
2015-8-7
quasimodo
Malaysia
sploodge Posted at 2015-8-4 15:41
This FW works well.. VPS issue is resolved..
Can u explain in detail meaning vps issue is resolved.
2015-8-13
1anr0bbins
I'd like some feedback on this issue - got my phantom 3 advanced a few weeks ago, flew 3 times using my acer iconia tablet running android 4.4  Now, after my last flight I saw the upgrade so I installed the new 1.3.20 firmware on the phantom. all ok. then I tried the controller and no good. So then I upgraded my tablet to DJI GO as it was available(version 2.0.1) and the screen shows up nice then it says unfortunately DJI GO has stopped...So I uninstalled/installed it about 6 times with the same results (nothing). Just for shits and giggles I tried to upload DJI GO to my samsung s5 phone which uses android 5.0 and everything came up great, got the controller updated and for the first time saw the blue light. My issue is do I have to go out and buy a new tablet with android 5.0 minimum or will there be a fix for my tablet which runs android 4.4, because the DJI website says you need minimum android 4.1.2? I don't have a lot of money to keep going out and buying tablets and my wife won't let me use the phone for flying( shes says only calls and txt..lol, women)
2015-8-15
BRENT1956
Flight distance : 3686975 ft
Willie Wonka Posted at 2015-8-4 22:13
Hell I am gonna be buying DJI STOCK if available!!!
Better just invest in the Chocolate Factory!  Go sucks, cannot get videos in library, nor in Favorites in Flight Log and usual "Map Loading" in Location, sucks! any help anyone!
2015-9-19
BRENT1956
Yeah, Right!, I have no videos stored to my Library to even see Director, My Locations just says "Map Loading", no location. In my Flight Record-No favorates, just blank boxes, such a wonderfuls new App!
Anyone have any info on how to get these working on a Android device? Everything else seem to work okay in Groundstation , but I cannot even earn points they bragg about because in my LV rating it goes down instead of up! 150 flights with nothing to show for it but my SD Card!
2015-9-19
12
