rayrokni
Flight distance : 8139875 ft
well, if your orig. fw was 126 and the new update132 did not work, the old fw will still be on the p3 and if u try to as u said downgrade to 126. its not going to do anything as it sees the 126fw same or older than the 126 already on it.
the original problem of loosing video could be because of a few other factors. i suggest leaving the update be til u get back, meanwhile take it out and see if you have good gps signal, chk your mod values in sensor settings, manually chk the compass bearing if u can, use ur smartphone and find north, mark a line and put the nose of p3 on that line and see if that corresponds correctly on the map view. make sure u have enabled multi flights in the settings( in case u need to go to atti mode). arm the motors and let it sit there for a few minutes. if you dont hear any odd noises or speed changes in the motor, take off manually and hover at six feet for a few minutes, again listen for any odd noises. then fly it at that altitude using all the different movements u can. basically use a whole battery for all the tests you can do, make sure you are videoing all the time. if all goes well then you gotta take it higher and further with the second battery. if u feel its doing everything ok then depends how brave u r in taking it out fully to video!!
good luck |
