Firmware 1.3.20 - DJI Go 2.0.0 App Discussion Thread
29847 296 2015-8-3
astrostar
jsfarms69@gmail Posted at 2015-8-8 01:56
What worked for me is connect the RC to the tab, turn on RC, then the Tab. (do not turn on the Pha ...
Just updated my P3P to the latest firmware and all went well
========== 2014.01.01 00:00:13 unsynchronized ======
Packet: P3X_FW_V01.03.0020.bin
Upgrading ...
Result: Success.
I then updated the RC (GL-300A) and the .TXT file read as follows...
P3_FW_GS_LOG.txt
[1438879181.341271] RC upgrade log:
[1438879189.430614] start upgrade 13
[1438879209.613434] success
[1438879212.630061] start upgrade 14
[1438879235.674370] success
P3_FW_RESULT_GS.txt
==========2015.08.06 16:39:41==========
Packet: /mnt/usb/P3X_FW_V01.03.0020.bin,
Upgrading ...
Result: Success
but having checked the DJ Pilot APP (Android) it still shows FW version as 1.2.0
The RC was updated using a USB stick directly in the USB port on the controller.
Is this correct or have I missed something ?
2015-8-7
L8again
Your pilot app is 1.2.0 until they get the GO app out for android. FW is 1.3.2
2015-8-7
astrostar
L8again Posted at 2015-8-8 04:01
Hi L8again,
Thanks for the info. I thought I had to upgrade the RC with the new FW even though it's the Android app that I'm running, but I guess I shall have to wait for the Android version of the GO app to appear.
Just realised I'm confusing the RC firmware version with the Pilot app version - DOH !
Many Thanks.
2015-8-7
Booradley
Flight distance : 11349537 ft
Thank you, I'll give it a go in a few hours when I get out of work.
2015-8-7
thisisafish
Denmark
I guess I turned mine off before it was finished (yes yes - but was at party eager to fly) and the result was what looked liked a bricked battery and the P3 craft was beeping VERY loud and intense in a scary way.. The P3 craft did finally get into "normal beep" mode (after 15 minutes?) but then went into a long hissing noise for an hour - couldn't turn it off, so pulled the battery out.. Then I doinked in my spare battery, and it finally finished. The other battery was non-responsive pressing the button and in the charger, but when I inserted it into the craft it immediately started - so prepared the flash card again and thing is back to normal again now.. So:
1) Don't drink and firmware!
2) The upgrade takes a long time - especially if you do wrong
3) If it fails - the P3 is actaully very good at self-resetting etc. (very hard to brick?) - nice
4) The DJI engineers has invented a lot of flashing and beeping modes - including really loud ones
2015-8-7
hundleton1
Flight distance : 2741657 ft
Guys with the firmware its this easy,
Craft, Look at the led on the front of the gimbal
Flashing Green/Red Update in Progress
Solid Green Update complete
Solid Red Update failed
Controller
Solid Blue in Progress
Solid Green When Complete
Follow this and you should not be able to go wrong.
2015-8-7
fred
hundleton1 Posted at 2015-8-8 07:25
ok, so the update is failing.....looks like some component has failed and has not been detected.  But, it should not cause the update to fail...but it has.  Wish I knew what failed.
[00015212]Version checking[1]...
[00015320][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015425][03 06][00] v2.2.6.19 -> v2.2.6.19
[00015487][04 00][00] v1.40.0.0 -> v1.40.0.0
[00015576][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015719][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015833][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015929][12 01][00] v1.8.0.0 -> v1.8.0.0
[00016032][12 02][00] v1.8.0.0 -> v1.8.0.0
[00016159][12 03][00] v1.8.0.0 -> v1.8.0.0
[00028717][15 00][00] device not detected.
[00028824][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028969][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029043][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029101][01 00][00] v1.23.3419 -> v1.23.3419
[00029159][01 01][00] v1.23.3419 -> v1.23.3419
[00041714][08 00][00] device not detected.
[00041771]Packet upgrade failed at version checking.
2015-8-7
mpdigiman
Took out my Phantom 3 pro tiday after doing the update followed by IMU & Gimbal. Calibration.
2015-8-7
kriskhalil
Honduras
rayrokni Posted at 2015-8-7 14:07
well, if your orig. fw was 126 and the new update132 did not work, the old fw will still be on the ...
But I can't video! the gimbal droops. The APP doesn't even recognize that I have an SD card in there!
2015-8-7
kriskhalil
Honduras
I've tried all of these suggestions guys. Im starting to get worried I will not be able to fly on my trip in paradise! :-(
2015-8-7
mpdigiman
Took up my Phantom 3 pro today after doing the update followed by IMU & Gimbal Calibration. All went well but on two occasions i got lost rc signal. This was for a split second each time i was surprised to see that the video recorded shows horizontal flikering lines in two places on the clip. I put this down to the lost signal. Can someone confirm if the split second loss of signal caused this? I would have thought the video would not habe been affected since the recording started at take-off...and finished before landing..... Confused?.
2015-8-7
kriskhalil
Honduras
The Gimbal LEDs do not work anymore...
2015-8-7
ScottyT
fred Posted at 2015-8-8 08:55
ok, so the update is failing.....looks like some component has failed and has not been detected.   ...
That doesn't look good. I've not been following the firmware upgrade issues but that looks like you'll have to contact DJI for help.
2015-8-7
coastodian
1.3.20 update
P3A
the craft has updated (according to the lights and the txt file
unable to update the RC, either via the app (version 2.0.0), or via the USB card reader.
model is GL 300A
app says i cannot update via app, use card reader.
when I plug in card reader, boot rc, the status light never goes to blue, always stays red.
after a about 5 minutes, the RC starts beeping loudly
tried it 3 times, same result with app or card reader
P3P
I am unable to update the craft.
The lights alternate from red to green for as long as up to an hour. Sometimes for a moment it stays solid green, then goes off, then alternates again. Always with the D-D-D-D sound
Nothing has ever been written to a txt file on the card.
have reformatted card twice (exFat), same result.
controller will not update either (GL 300A)
So, out of 2 craft, 2 RC, I am only able to update the P3A to the latest FW. Ap on ipad is at 2.0.0
Any tips?
The P3P is going back to the dealer.
more data
used entirely different CF card from my DSLR, formatted it to exFat, copied P3A FW to it and was able to update P3A remote.
deleted P3A FW, replaced it with P3P FW and was able to update P3P RC.
formatted the 16 GB lexar card that came with P3P, copied FW for P3P to it and insterted in P3P, started up.
very loud BEEP BEEP for about 5 minutes, then it went to normal low level D-D-D-D sound of update for about 3 min, then did D-DD sound and light on gimbal went solid green.
txt files said success, yet, when I connect RC to it, the app says the upgrade failed and to do it again.
So I am inserted same card from above. Craft is silent, ginmbal light is solid green.
txt file said:
========== 2015.08.07 21:30:07 =====================
Result: Corrupted.
Firmware bin file is corrupted, download it again from the DJI offical website.
========== 2015.08.07 21:35:40 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft..
So I download again
Craft is silent and light is solid green.
Now txt files says:
========== 2015.08.07 21:51:11 =====================
Result: Abort.
DJI should be paying me to debug their product
any tips from the experts are appreciated.
thank you
2015-8-7
hundleton1
it looks like there may be an issue with the firmware update, a few reports are coming of the same error, hold off a few days its been passed back by Ed,
sorry not the ideal answer but hopefully its something they can fix in fw quickly
2015-8-7
sploodge
Flight distance : 809350 ft
just an option coastodian, can you format the SD card using the DJI App, put the firmware BIN on it and try updating again.
Also, after whatever happens or not, can you look for a hidden folder on the SD card called /MISC/LOG and post the contents of any TXT file in there also. Its a long shot but has resolved this issue for some.
Like hundleton says, two VERY similar cases has been identified and passed to DJI and there might be a few not classified as the same issue too. The TXT file in the /MISC/LOG gives much more detail.
Sorry you are having this issue, its been a fairly smooth one for most..
2015-8-8
coastodian
Thanks for your time and ideas guys.
here is contents of the file you ask for:
[00012230][01 00] Firmware upgrade finished successfully.
[00012361]Done.
[00012389]Packet [C:\P3X_FW_V01.02.0006.bin] resumed, card sn [0x90ce4ad2].
[00012422]Version checking[2]...
[00012484][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00012540][03 06][00] v2.1.6.18 -> v2.2.6.8 need upgrade.
[00012577][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00012623][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012740][11 00][00] v1.6.0.0 -> v1.6.0.0
[00012807][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012892][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012973][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013047][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013171][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013247][17 00][00] v1.1.1.2 -> v1.1.1.6 need upgrade.
[00013367][17 01][00] v1.0.2.4 -> v1.0.2.5 need upgrade.
[00013422][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00013450][01 00][05] v1.15.3056 -> v1.15.3056
[00013487][01 01][00] v1.6.2736 -> v1.15.3056 need upgrade
[00013529][08 00][00] v0.11.0.4 -> v0.11.0.4
[00013558]Done.
[00013585]Firmware upgrading[2]...
[00013732][01 01] Firmware upgrade start...
[00043987][01 01] Firmware upgrade finished successfully.
[00044043][17 00] Firmware upgrade start...
[00134368][17 00] Firmware upgrade finished successfully.
[00134411][17 01] Firmware upgrade start...
[00197212][17 01] Firmware upgrade finished successfully.
[00197260][03 05] Firmware upgrade start...
[00269990][03 05] Firmware upgrade finished successfully.
[00270205][03 06] Firmware upgrade start...
[00560321][03 06] Firmware upgrade finished successfully.
[00563127][19 00] Firmware upgrade start...
[00729502][19 00] Firmware upgrade finished successfully.
[00729566][04 00] Firmware upgrade start...
[00787131][04 00] Firmware upgrade finished successfully.
[00787160]Done.
[00787191]Version checking[3]...
[00787295][03 05][05] v34.2.0.9 -> v34.2.0.9
[00787370][03 06][05] v2.2.6.8 -> v2.2.6.8
[00787406][04 00][05] v1.38.0.0 -> v1.38.0.0
[00787471][09 00][00] v1.7.0.3 -> v1.7.0.3
[00787670][11 00][00] v1.6.0.0 -> v1.6.0.0
[00787765][12 00][00] v1.8.0.0 -> v1.8.0.0
[00787844][12 01][00] v1.8.0.0 -> v1.8.0.0
[00787919][12 02][00] v1.8.0.0 -> v1.8.0.0
[00788004][12 03][00] v1.8.0.0 -> v1.8.0.0
[00788144][15 00][00] v1.1.2.0 -> v1.1.2.0
[00788219][17 00][05] v1.1.1.6 -> v1.1.1.6
[00788340][17 01][05] v1.0.2.5 -> v1.0.2.5
[00788391][19 00][05] v1.0.8.96 -> v1.0.8.96
[00788428][01 00][05] v1.15.3056 -> v1.15.3056
[00788458][01 01][05] v1.15.3056 -> v1.15.3056
[00788498][08 00][00] v0.11.0.4 -> v0.11.0.4
[00788525]Packet upgrade finish successfully.
[00013407]========== 2015.07.04 17:27:18. boot(15) ============
[00013518]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x90ce4ad2].
[00013626]Packet upgrade start...
[00013769]Packet checking...
[00013879]Done.
[00013935]Version checking[1]...
[00014077][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014238][03 06][00] v2.2.6.8 -> v2.2.6.8
[00014379][04 00][00] v1.38.0.0 -> v1.38.0.0
[00014556][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014744][11 00][00] v1.6.0.0 -> v1.6.0.0
[00014910][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015067][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015190][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015267][12 03][00] v1.8.0.0 -> v1.8.0.0
[00015414][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015507][17 00][00] v1.1.1.6 -> v1.1.1.6
[00015627][17 01][00] v1.0.2.5 -> v1.0.2.5
[00015674][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015708][01 00][00] v1.15.3056 -> v1.15.3056
[00015745][01 01][00] v1.15.3056 -> v1.15.3056
[00015799][08 00][00] v0.11.0.4 -> v0.11.0.4
[00015833]Packet upgrade cancelled at version checking.
[00013403]========== 2015.07.04 17:40:36. boot(15) ============
[00013504]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x90ce4ad2].
[00013552]Packet upgrade start...
[00013695]Packet checking...
[00013800]Done.
[00013913]Version checking[1]...
[00014045][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014206][03 06][00] v2.2.6.8 -> v2.2.6.8
[00014455][04 00][00] v1.38.0.0 -> v1.38.0.0
[00014559][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014742][11 00][00] v1.6.0.0 -> v1.6.0.0
[00014915][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015071][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015238][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015400][12 03][00] v1.8.0.0 -> v1.8.0.0
[00015618][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015774][17 00][00] v1.1.1.6 -> v1.1.1.6
[00015926][17 01][00] v1.0.2.5 -> v1.0.2.5
[00015980][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016017][01 00][00] v1.15.3056 -> v1.15.3056
[00016054][01 01][00] v1.15.3056 -> v1.15.3056
[00016094][08 00][00] v0.11.0.4 -> v0.11.0.4
[00016131]Packet upgrade cancelled at version checking.
[00013040]========== 2015.07.04 17:42:20. boot(15) ============
[00013075]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x90ce4ad2].
[00013112]Packet upgrade start...
[00013161]Packet checking...
[00013203]Done.
[00013240]Version checking[1]...
[00013308][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013393][03 06][00] v2.2.6.8 -> v2.2.6.8
[00013437][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013487][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013613][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013704][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013803][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013903][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014003][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014143][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014238][17 00][00] v1.1.1.6 -> v1.1.1.6
[00014357][17 01][00] v1.0.2.5 -> v1.0.2.5
[00014407][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014441][01 00][00] v1.15.3056 -> v1.15.3056
[00014476][01 01][00] v1.15.3056 -> v1.15.3056
[00014527][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014561]Packet upgrade cancelled at version checking.
[00000831][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff).
[00000830][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff).
[00000833][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff).
[00012428]========== remo-con disconnect. boot(15) ============
[00012469]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x28a78402].
[00012506]Packet upgrade start...
[00012557]Packet checking...
[00012592]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012664]Done.
[00012700]Version checking[1]...
[00012765][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012841][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00012883][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00012944][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013064][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00013154][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013230][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013320][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013394][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013531][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013612][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00013730][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00013784][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013834][01 00][00] v1.23.3419 -> v1.23.3419
[00013869][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00013919][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00013959]Done.
[00015996]Waiting for user confirm...
[00026032]Timeout, start upgrade automatically.
[00026099]Firmware upgrading[1]...
[00026248][01 01] Firmware upgrade start...
[00056475][01 01] Firmware upgrade finished successfully.
[00064432][08 00] Firmware upgrade start...
[00573646][08 00] Firmware upgrade finished successfully.
[00582292][17 00] Firmware upgrade start...
[00708609][17 00] Firmware upgrade finished successfully.
[00717229][17 01] Firmware upgrade start...
[00797071][17 01] Firmware upgrade finished successfully.
[00805679][11 00] Firmware upgrade start...
[00863965][11 00] Firmware upgrade finished successfully.
[00872742][03 06] Firmware upgrade start...
[00012633]========== remo-con disconnect. boot(15) ============
[00012673]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce4ad2].
[00012718]Packet upgrade start...
[00012766]Packet checking...
[00012805]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012878]Done.
[00012924]Version checking[1]...
[00012998][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013058][03 06][00] v0.0.0.0 -> v2.2.6.19 need upgrade.
[00013106][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00013168][09 00][00] v1.7.0.3 -> v1.7.0.3
[00025711][11 00][00] device not detected.
[00038253][12 00][00] device not detected.
[00050790][12 01][00] device not detected.
[00063345][12 02][00] device not detected.
[00075882][12 03][00] device not detected.
[00076037][15 00][00] v1.1.2.0 -> v1.1.2.0
[00088579][17 00][00] device not detected.
[00101116][17 01][00] device not detected.
[00101193][19 00][00] v1.0.8.96 -> v1.0.8.96
[00101233][01 00][00] v1.23.3419 -> v1.23.3419
[00101280][01 01][00] v1.23.3419 -> v1.23.3419
[00101340][08 00][00] v0.12.0.4 -> v0.12.0.4
[00101380]Done.
[00103418]Waiting for user confirm...
[00113458]Timeout, start upgrade automatically.
[00113533]Firmware upgrading[1]...
[00113741][03 06] Firmware upgrade start...
[00410059][03 06] Firmware upgrade finished successfully.
[00410128][04 00] Firmware upgrade start...
[00467927][04 00] Firmware upgrade finished successfully.
[00467970]Done.
[00468010]Version checking[2]...
[00468092][03 05][00] v34.2.0.9 -> v34.2.0.9
[00468172][03 06][05] v2.2.6.19 -> v2.2.6.19
[00468216][04 00][05] v1.40.0.0 -> v1.40.0.0
[00468273][09 00][00] v1.7.0.3 -> v1.7.0.3
[00468397][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00468482][12 00][00] v1.8.0.0 -> v1.8.0.0
[00468563][12 01][00] v1.8.0.0 -> v1.8.0.0
[00468673][12 02][00] v1.8.0.0 -> v1.8.0.0
[00468762][12 03][00] v1.8.0.0 -> v1.8.0.0
[00468899][15 00][00] v1.1.2.0 -> v1.1.2.0
[00468997][17 00][00] v1.1.1.7 -> v1.1.1.7
[00469122][17 01][00] v1.0.2.7 -> v1.0.2.7
[00469274][19 00][00] v1.0.8.96 -> v1.0.8.96
[00469315][01 00][00] v1.23.3419 -> v1.23.3419
[00469356][01 01][00] v1.23.3419 -> v1.23.3419
[00469405][08 00][00] v0.12.0.4 -> v0.12.0.4
[00469448]Done.
[00469488]Firmware upgrading[2]...
[00469543][11 00] Firmware upgrade start...
[00517670][11 00] Firmware upgrade finished successfully.
[00517710]Done.
[00517751]Version checking[3]...
[00517835][03 05][00] v34.2.0.9 -> v34.2.0.9
[00517915][03 06][05] v2.2.6.19 -> v2.2.6.19
[00517967][04 00][05] v1.40.0.0 -> v1.40.0.0
[00518034][09 00][00] v1.7.0.3 -> v1.7.0.3
[00518157][11 00][05] v1.7.0.0 -> v1.7.0.0
[00518244][12 00][00] v1.8.0.0 -> v1.8.0.0
[00518324][12 01][00] v1.8.0.0 -> v1.8.0.0
[00518470][12 02][00] v1.8.0.0 -> v1.8.0.0
[00518570][12 03][00] v1.8.0.0 -> v1.8.0.0
[00518697][15 00][00] v1.1.2.0 -> v1.1.2.0
[00518786][17 00][00] v1.1.1.7 -> v1.1.1.7
[00518925][17 01][00] v1.0.2.7 -> v1.0.2.7
[00518996][19 00][00] v1.0.8.96 -> v1.0.8.96
[00519035][01 00][00] v1.23.3419 -> v1.23.3419
[00519077][01 01][00] v1.23.3419 -> v1.23.3419
[00519131][08 00][00] v0.12.0.4 -> v0.12.0.4
[00519176]Packet upgrade finish successfully.
[00088455]========== 2015.08.07 21:30:24. boot(15) ============
[00088492]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x28a78402].
[00088529]Packet upgrade start...
[00088568]Packet upgrade failed at packet checking.
[00012529]========== 2015.08.07 21:35:41. boot(15) ============
[00012568]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce4ad2].
[00012613]Packet upgrade start...
[00012661]Packet checking...
[00012700]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012740]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012785]Done.
[00012825]Version checking[1]...
[00012912][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012993][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013043][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013112][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013232][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013412][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013512][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013601][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013711][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013875][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013976][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014117][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014175][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014218][01 00][00] v1.23.3419 -> v1.23.3419
[00014285][01 01][00] v1.23.3419 -> v1.23.3419
[00014333][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014377]Packet upgrade cancelled at version checking.
[00012527]========== 2015.08.07 21:51:12. boot(15) ============
[00012662]Packet checking...
[00012701]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012743]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012788]Done.
[00012828]Version checking[1]...
[00012915][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012996][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013048][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013115][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013241][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013335][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013436][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013536][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013630][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013783][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013884][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014030][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014094][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014144][01 00][00] v1.23.3419 -> v1.23.3419
[00014185][01 01][00] v1.23.3419 -> v1.23.3419
[00014280][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014318]Packet upgrade cancelled at version checking.
2015-8-8
fred
coastodian Posted at 2015-8-8 23:51
Mine is similar but a little different.   I always have the .bin on my sd card so I can see all my boot ups.  I see that everything was happy with 1.2.6 but then, out of the blue, it gives this message:
[00014473]========== remo-con disconnect. boot(15) ============
now there are two device not detected messages in the list:
[00027975][15 00][00] device not detected.
[00040967][08 00][00] device not detected.
I must have power cycled the craft because while the next boot says:
[00012486]========== remo-con disconnect. boot(15) ============
it does not have the device not detected, instead it shows those two devices as being on the current version.
And things are happy for a while, until 1.3.2 when I get the remo-con message and then the following.  I don't know if the subcomponent has a failed bit of the firm ware or what but I do know one thing:
I can't downgrade because the package bails on the version checking before it even sees to downgrade.  here is the rest of the log, there is more but it is just the same thing with device not detected on the two items.
[00014480]========== remo-con disconnect. boot(15) ============
[00014519]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x88f02ae8].
[00014560]Packet upgrade start...
[00014607]Packet checking...
[00014646]Done.
[00014686]Version checking[1]...
[00014762][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014842][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00014887][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00014936][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015060][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00015150][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015250][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015433][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015530][12 03][00] v1.8.0.0 -> v1.8.0.0
[00028070][15 00][00] device not detected.
[00028166][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00028306][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00028377][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028420][01 00][00] v1.15.3056 -> v1.23.3419 need upgrade
[00028464][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00041009][08 00][00] device not detected.
[00041051]Done.
[00043094]Waiting for user confirm...
[00053136]Timeout, start upgrade automatically.
[00053228]Firmware upgrading[1]...
[00064805][01 00] Firmware upgrade start...
[00014238][01 00] Firmware upgrade finished successfully.
[00014280]Done.
[00014322]Packet [C:\P3X_FW_V01.03.0020.bin] resumed, card sn [0x88f02ae8].
[00014366]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014440]Version checking[2]...
[00014524][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014604][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00014657][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00014719][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014844][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00014933][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015033][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015133][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015233][12 03][00] v1.8.0.0 -> v1.8.0.0
[00027777][15 00][00] device not detected.
[00027874][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00028015][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00028080][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028125][01 00][05] v1.23.3419 -> v1.23.3419
[00028167][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00040709][08 00][00] device not detected.
[00040750]Done.
[00040794]Firmware upgrading[2]...
[00040937][01 01] Firmware upgrade start...
[00071186][01 01] Firmware upgrade finished successfully.
[00071253][17 00] Firmware upgrade start...
[00161781][17 00] Firmware upgrade finished successfully.
[00161837][17 01] Firmware upgrade start...
[00228320][17 01] Firmware upgrade finished successfully.
[00228369][11 00] Firmware upgrade start...
[00277595][11 00] Firmware upgrade finished successfully.
[00277810][03 06] Firmware upgrade start...
[00573141][03 06] Firmware upgrade finished successfully.
[00573208][04 00] Firmware upgrade start...
[00630756][04 00] Firmware upgrade finished successfully.
[00630796]Done.
[00630838]Version checking[3]...
[00630922][03 05][00] v34.2.0.9 -> v34.2.0.9
[00631002][03 06][05] v2.2.6.19 -> v2.2.6.19
[00631060][04 00][05] v1.40.0.0 -> v1.40.0.0
[00631116][09 00][00] v1.7.0.3 -> v1.7.0.3
[00631245][11 00][05] v1.7.0.0 -> v1.7.0.0
[00631345][12 00][00] v1.8.0.0 -> v1.8.0.0
[00631431][12 01][00] v1.8.0.0 -> v1.8.0.0
[00631515][12 02][00] v1.8.0.0 -> v1.8.0.0
[00631616][12 03][00] v1.8.0.0 -> v1.8.0.0
[00644159][15 00][00] device not detected.
[00644251][17 00][05] v1.1.1.7 -> v1.1.1.7
[00644391][17 01][05] v1.0.2.7 -> v1.0.2.7
[00644457][19 00][00] v1.0.8.96 -> v1.0.8.96
[00644499][01 00][05] v1.23.3419 -> v1.23.3419
[00644541][01 01][05] v1.23.3419 -> v1.23.3419
[00657084][08 00][00] device not detected.
[00657125]Packet upgrade failed at version checking.
[00014528]========== remo-con disconnect. boot(15) ============
[00014571]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x88f02ae8].
[00014616]Packet upgrade start...
[00014662]Packet checking...
[00014703]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014777]Done.
[00014818]Version checking[1]...
[00014895][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014974][03 06][00] v2.2.6.19 -> v2.2.6.19
[00015023][04 00][00] v1.40.0.0 -> v1.40.0.0
[00015080][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015195][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015310][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015409][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015509][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015609][12 03][00] v1.8.0.0 -> v1.8.0.0
[00028153][15 00][00] device not detected.
[00028241][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028463][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028520][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028565][01 00][00] v1.23.3419 -> v1.23.3419
[00028609][01 01][00] v1.23.3419 -> v1.23.3419
[00041151][08 00][00] device not detected.
[00041193]Packet upgrade failed at version checking.
[00014481]========== remo-con disconnect. boot(15) ============
[00014523]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x88f02ae8].
[00014566]Packet upgrade start...
[00014610]Packet checking...
[00014650]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014727]Done.
[00014769]Version checking[1]...
[00014851][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014933][03 06][00] v2.2.6.19 -> v2.2.6.19
[00014981][04 00][00] v1.40.0.0 -> v1.40.0.0
[00015056][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015171][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015260][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015340][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015425][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015525][12 03][00] v1.8.0.0 -> v1.8.0.0
[00028069][15 00][00] device not detected.
[00028161][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028282][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028336][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028380][01 00][00] v1.23.3419 -> v1.23.3419
[00028423][01 01][00] v1.23.3419 -> v1.23.3419
[00040963][08 00][00] device not detected.
[00041004]Packet upgrade failed at version checking.
2015-8-8
sploodge
The last section at the bottom of this log shows it updated OK..
2015-8-8
fred
sploodge Posted at 2015-8-9 00:34
his is ok, mine just continually gets the device not detected...while everything works except video from the camera.
2015-8-8
sploodge
fred Posted at 2015-8-9 00:48
his is ok, mine just continually gets the device not detected...while everything works except vide ...
Hi Fred..
can you format the SD card when its in the Phantom using the DJI App. Then put the firmware back on it and try again..
2015-8-8
sploodge
Actually Fred.. I see Ed had got back to another user about this issue here - http://www.rcgroups.com/forums/s ... 969&postcount=30879 - I would wait and see what comes of this.. By all means give the option above a go though..
2015-8-8
fred
sploodge Posted at 2015-8-9 01:03
Actually Fred.. I see Ed had got back to another user about this issue here - http://www.rcgroups.co ...
hmm, can't wait.  thanks for the heads up.  Oh, and I have formatter the card using the app, with the sdcard in the craft, everything, result is the same, result file says
========== 2015.08.08 13:30:50 =====================
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
log file says:
[00014815]========== 2015.08.08 13:30:51. boot(15) ============
[00014902]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xb0ce0ac2].
[00014959]Packet upgrade start...
[00015018]Packet checking...
[00015089]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015184]Done.
[00015254]Version checking[1]...
[00015358][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015477][03 06][00] v2.2.6.19 -> v2.2.6.19
[00015553][04 00][00] v1.40.0.0 -> v1.40.0.0
[00015633][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015858][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015992][12 00][00] v1.8.0.0 -> v1.8.0.0
[00016127][12 01][00] v1.8.0.0 -> v1.8.0.0
[00016253][12 02][00] v1.8.0.0 -> v1.8.0.0
[00016372][12 03][00] v1.8.0.0 -> v1.8.0.0
[00028942][15 00][00] device not detected.
[00029066][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029227][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029317][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029382][01 00][00] v1.23.3419 -> v1.23.3419
[00029447][01 01][00] v1.23.3419 -> v1.23.3419
[00042011][08 00][00] device not detected.
[00042072]Packet upgrade failed at version checking.
2015-8-8
Booradley
Do you have the Samsung Galaxy Tab S (mine 8.4)?
I can confirm that you cannot update the RC through the application with the Samsung Galaxy Tab S 8.4.
2015-8-8
Nemmo
Russia
sploodge Posted at 2015-8-4 18:50
Here is an entire FW Upgrade video ( its long and boring but shows the phases the P3 goes through ). ...
Hello everybody.  About upgrade the batteries. So, when You upgrade firmware you don't see anything according to battery upgrade. Any add. lights or some special DDD..
But if You put in the new batt(not  current FW one) You will monitor the upgrade process.
After24 sec since Power On P3. DDD...DDD will appear and LED on camera starts blink red/green.
On the battery  some seconds later the second LED starts to blink and third will light stadly.
All will be finished in a 1:30min approx.. Camera LED becomes solid green and D..DD.. will be hear.
So, there is entire video.
2015-8-8
warrenkevin18
Has anyone experienced any differences in relation to the no fly zones?
2015-8-8
sploodge
warrenkevin18@g Posted at 2015-8-9 02:46
Not me.. But I do live where there is only ONE NFZ and its an RAF base so don't do too near to it
2015-8-8
warrenkevin18
sploodge Posted at 2015-8-9 02:54
Not me.. But I do live where there is only ONE NFZ and its an RAF base so don't do too near to it  ...
I was in a restricted zone today where my Alt is usually limited to 36m but today I wasn't promoted in the DJI go app and it continued above the limit, strange.
2015-8-8
cellulit
Poland
This damn upgrade takes so long, that in a moment the battery will go to zero. Camera led is solid green, but P3P is still making its old printer sound and blinking. I'll let it die and then see the results. Whatever it is, someone broke it. None of previous upgrades was that complicated and misleading.
Edit: my wife went nuts and I had to manually turn it off. Log says success. We'll see that in field tomorrow.
2015-8-8
suaveaerial
Flight distance : 41181 ft
Just curious - I don't even see the DJI Pilot app available for download anymore from the DJI website, just the Android version coming soon for DJI GO.  Is it advisable to still update the firmware on the aircraft and the RC?  Or wait until the Android version? Took the aircraft out today and noticed there was a firmware update required and I was unable to calibrate the compass while this message was displayed.  I'm pretty OCD about calibrating the compass before each flight so was a little nervous.
2015-8-8
cellulit
Poland
suaveaerial Posted at 2015-8-9 07:30
Just curious - I don't even see the DJI Pilot app available for download anymore from the DJI websit ...
I had same situation today and I WAS ABLE to calibrate before safely flying (and before upgrading). The firmware message isn't a show-stopper.
2015-8-8
Vermontflyer
Hello All, I apologize if I missed the info I need in the posts.
I'm stressing a bit, I downloaded the new firmware and put it in my drone like the last update but...
  nothing is happening the camera light is not blinking and no beeps after the initial one as it turns on.
have I messed up or is there a software problem ?
I greatly appreciate any assistance !
   Regards !
2015-8-8
Quadifier
Flight distance : 2664 ft
I've been wondering myself why the Pilot App is not available anymore... at least until the new app becomes available for download.  How are new owners supposed to be able to fly?  The Pilot App DOES work OK with the new 1.3.20 ver FW.  I flew two batteries last night using Pilot App and it was fine.
2015-8-8
Bhaapala
yegorius Posted at 2015-8-4 21:04
I can not update the firmware on Phantom 3 Pro (v1.3.20). At first time updating process was about 2 ...
I had the same problem, only now I turn on the aircraft and its just really loud beeping-no led blinking. did you figure out what happened?
2015-8-8
magart2.hotmail
sploodge Posted at 2015-8-4 16:02
Hovering is steady too.. Baro readings seem accurate again..
Sploodge, finally updated firmware today and it is like having a new bird, the thing flies absolutely perfect again. Hovers steady, vps works again and flies flawlessly.
2015-8-8
magart2.hotmail
magart2.hotmail Posted at 2015-8-9 11:44
Sploodge, finally updated firmware today and it is like having a new bird, the thing flies absolut ...
P.S. Phantom 3 Pro, nexus 7 II and 1.3.20. Still running 1.20 app.
2015-8-8
magart2.hotmail
kgjamison Posted at 2015-8-4 21:09
Thanks for the instructions! Question, I did not do the last update. Should I update the contoller ...
I just jumped to the 1.3.20 and all works fine. Phantom 3 Pro, nexus 7II.
2015-8-8
dirk.liesenfeld
Booradley Posted at 2015-8-8 00:39
Hey Dirk,
I am also using the Samsung Galaxy Tab S and was wondering how you updated the remote c ...
I used the USB-Cable to update. You have to test different cables, some seem to work better than others.
I didn't downgrade the playservices and flew in very hot weather with direct sun onto the tablet - almost no video lag at all. Tried another flight with downgraded playservices and it was even better. But the difference is so slight, that I do not downgrade anymore, because the tablet is a daily driver for me.
I think, that the new DJGo App will be even perfect(er), so I am waiting for it, hoping and praying.
But I am a happy camper already (again)!
2015-8-8
DanH
Flight distance : 315177 ft
Updated to latest firmware and IOS DJI Go app.
Everything is working fine, hovering is rock solid, VPS works like a charm.
The only issue I encountered is that I cannot retrieve my flight logs anymore on the iPad Air 2. It looks like the iPad is recording something, but I cannot drag/drop the DJI Go files from iTunes as I did before.
Not sure if it is because I'm running IOS 9 Beta 3, but it worked  fine with DJI Pilot.
2015-8-9
sploodge
Good to hear, happy flying..
2015-8-9
