djiuser_xWQsTDnAbLik
Flight distance : 50584 ft
Hi Peter,
I have taken a look on the new Version 3.0.1 ;-)
It`s a bugfix ---- Now the tool works as it should.
It does not crash anymore while starting. For "not readable files" such as normal jpg's the thumnails are "crossed" with an icon.
Would be great if these pictures could just be displayed without any editing possibilities. Or ist it possible to start automatically the corresponding programm for this file type ?
At the moment the only thing i am still missing is the possibility to create a "free" shaped area that can be measured by drawing a line line ("Polygon" ?) and setting several points - this was possible in Version 2.
Another point I am wondering about is why the text size is adjustable (small, medium, large) while the text location is "middle" but as soon as the text ist in a box (text position: left or right) only the "name of the area" ist adjustable, the text in the box does not change the seize ---- another bug ?
The color of the text is due to the dark and light outline somehow readable ---- a possibility to change the text color individually would be nice.
Is there a possibility to delete all items at once, I have just found an option to delete one Item at a time ?
It would be nice if you could define a temperature range and everything outside this range will be sort of "greyed" (slightly darkened)
Beside this wishes this tools works good.
In total this vcersion is much more @user friendly@ than version 2. xxx
Greetings Marc |
