Another propeller holder on Amazon
1370 17 2022-7-10
fans5d3e3440
Flight distance : 4964 ft
Anyone tried this holder.
It looks like it shouldn't put any pressure on the blades like most that wrap around the drone.
2022-7-10
DowntownRDB
Flight distance : ****
I bought those.  The description is a bit off as they were not made of soft silicone but 3D printed from hard plastic.  I was afraid they would scratch the drone taking them of and putting them on.  They did fit a bit tight and seemed to hold the prop tips down a bit too much.  I was also a bit worried about long term durability of the plastic material used.  I binned them and order one that is much better made, fits perfectly and doesn't seem to be too tight on the props.
https://www.dronevalley.com/apps/search?q=Mini+3
2022-7-10
fans5d3e3440
DowntownRDB Posted at 7-10 18:24
Thanks for the insight.  It's not a lot of outlay, but it's still down the drain if you don't use the product.
2022-7-10
DJI Stephen
Hello there. Good day and thank you for reaching out. I hope that our fellow DJI Co Pilots who owns the DJI Mini 3 Pro and have tried using this accessory ( Propeller Holder Strap ) on there DJI Drone can give out the best recommendation and information with regard to this matter. Thank you.
2022-7-10
Bigplumbs
Flight distance : 620164 ft
I bought some previous ones but to be honest I am finding with use it is fine having no strap at all far less faff that way
2022-7-10
DAFlys
Im just using a little pull string bag to keep mine safe when packing it another bag for hiking.
2022-7-10
DowntownRDB
fans5d3e3440 Posted at 7-10 20:45
You're very welcome.
2022-7-11
KLRSKIR
Flight distance : 28675886 ft
I grabbed this for those situations that I just toss the little guy on the passenger seat. It even will fit in the GPC hardcase. It also protects the downward facing cameras.
2022-7-11
Sree
Did any one use a velcro as Prop Holder Strap ?
2022-7-20
djiuser_WNMKvutofePI
Flight distance : 133110 ft
Sree Posted at 7-20 19:38
That is what I am presently using.  I have a 1" wide, 10" long strip of velcro.
2022-7-20
fans5d3e3440
djiuser_WNMKvutofePI Posted at 7-20 20:27
But in order to make it tight enough not to slip off the drone, isn't that still going to exert some pressure on the propeller tips, which is what we're all trying to avoid.
2022-7-20
Stephen Carney
Flight distance : 70873 ft
I use a rubber band
2022-7-20
chillibadger
Flight distance : 233064 ft
I use these however whilst storing the drone in my hard case the bottom one comes off as there's a big rectangle that the props sit parallel to
2022-7-20
juan55
Flight distance : 577096 ft
I use a wide rubber band too
2022-7-20
SafariMan
Flight distance : 67703 ft
Switzerland
Yes, and you can adjust the pressure at your needs. For just a few cents
2022-7-21
Sree
SafariMan Posted at 7-21 00:04
Yeah
2022-7-21
Sree
Yeah
2022-7-21
MS
I stick in an old food box. Perfect fit with the sloped sides of the box. I currently have another 2 carry cases in the freezer
2022-7-21
