DJI Natalia
Hi, there. We are sorry for any inconvenience caused. Please don't worry about this issue and please check your firmware version.
Then you can check the below details:
When the aircraft firmware is v01.00.04.00 or an earlier version,
the aircraft will disable vision sensors when it is on the ground to reduce power consumption. When the aircraft takes off, all vision sensors will be enabled. Please feel free to use them.
When the aircraft firmware is v01.00.05.00 or a later version,
the aircraft will disable vision sensors when it is on the ground to reduce power consumption. After the propellers rotate, all vision sensors will be enabled. Please feel free to use them.
And if you have any more needs or questions, please just feel free to contact us at any time. |
