POLL: New Gimbal Design for Mini3
123Next >
6329 83 2022-7-12
DAFlys
There appears to be a new design of gimbal guard being reported as coming with the latter Mini 3 Pros.
Which guard did you get, and if you got option B when did you get the drone.
Single SelectVote, Total 146 people participate in voting
Your user group with no voting privileges
2022-7-12
DowntownRDB
Flight distance : ****
I do like the looks of gimbal guard B but mine came with A.  Bet B style will be on Aliexpress before long.
2022-7-12
DAFlys
DowntownRDB Posted at 7-12 04:03
On mine the blades in A have left a little tiny mark on the camera,  but then all the drones I had have suffered this too.  I always blamed it on the fact I walk with them many miles and they are bouncing around.
2022-7-12
DowntownRDB
DAFlys Posted at 7-12 04:17
Yeah, that bouncing around could be the cause.  At first, it was a real pain to get it back on but I finally got better at it.  I think I'll pick up one from Aliexpress like B if they list them.
2022-7-12
JMR58
Flight distance : 627966 ft
Belgium
Replacement arrived today(12 July) with the B Gimbal guard and a small profiled cushion, its much easier to fit.
2022-7-12
JMR58
Belgium
2022-7-12
Beta5K
Flight distance : 196880 ft
Where do you find the mfg date?
I received mine on 7/8 and got gimbal cover B.
2022-7-12
DocSavage
Flight distance : 48107 ft
Personally i realy dont care, i got A and it does what its ment to do.
Dont realy see the point of this poll.
2022-7-12
Bigplumbs
Flight distance : 620164 ft
DocSavage Posted at 7-12 08:37
Perhaps others see the point. If you don’t then just walk on by and smile.
Have you even got a mini 3
2022-7-12
djiuser_y1jNlO6fvE4e
Flight distance : 6148 ft
I got B gimbal guard and a small profiled cushion, manufacture date 05/2022, from Amazon.
2022-7-12
djiuser_UiOpbSlvbHqN
Flight distance : 249249 ft
I was the original poster who brought the new guard to light.  I completely failed to mention the newer design cushion.  I had that as well (but I threw it away).
2022-7-12
DocSavage
Bigplumbs Posted at 7-12 08:48
So explaine what the point of this poll is?
2022-7-12
tanasit
Flight distance : 145509 ft
Mine came with type A and at first I had tough time putting back on but now I got better but still have to be very careful.
I just ordered type C from: ($3.79 and Free shipping to US)
https://www.aliexpress.com/item/ ... .0.0.280ef19c8zx2sV
Perhaps it will be easier to put on because of the dual front camera cover as a guide.
2022-7-12
Flormo2002
Flight distance : 13963540 ft
DocSavage Posted at 7-12 09:39
Exactly other than the fact it probably shows your Mini 3 has a later production date compared to A photo guard. Wondering if the folks with the B photo guard have less issues with range of their drone?
2022-7-12
MySky
Flight distance : 364902 ft
I have never had any issues with A and also never used the foam that was between the camera and the body on delivery.
2022-7-12
MySky
Beta5K Posted at 7-12 08:13
On the outside of the box below the bar codes.
2022-7-12
Oracle Miata
Flight distance : 3759829 ft
djiuser_y1jNlO6fvE4e Posted at 7-12 09:00
I got A with a cushion that I pitched, manufactured in 5/2022, and also from Amazon.
2022-7-12
Bashy
Flight distance : 2354357 ft
You could always dremmel the two inner lines, this would i would be inclined to do if it was a paint to put on, i hate faffing about...
2022-7-12
DJI Stephen
Hello there DAFlys. Good day and thank you for creating this post. I hope that our fellow DJI Co Pilots can give out there valued insights and the best information with regards to this matter. Thank you.
2022-7-12
nosnoop
Flight distance : 237953 ft
The new design B should be much easier to put on, but it does not immobilize the gimbal head at all.   All it does is to prevent anything else touching it.
The original design A should be more protective for the gimbal as it prevents any movement during transportation - though you must remember to remove it before turning the drone on.
If I use the new design B, I would use the foam to immobilize the head + cover; whereas using the foam is optional for design A.   (previously used foam to ease putting the cover on, but now I find putting the cover is quite easy if I position the drone vertically; so I have stopped using the foam with design A.)
2022-7-12
DAFlys
Do you think its supposed to be used with the cushion?
2022-7-12
DAFlys
The A guard appears to mark the camera over time,  if they redesigned it already there must be a reason for it.
2022-7-12
JMR58
Belgium
DAFlys Posted at 7-12 21:48
anyway when I use the cushion the gimbal sits very tight, so I think it is the way to use it ...
2022-7-13
Wiganer
Flight distance : 48031 ft
Just received my 3rd drone after the original and replacement had to be sent back to DJI due to faults.
Original drone had a manufacture date of 04/2022 and had gimbal cover A.
Replacement drone had a manufacture date of 05/2022 and had gimbal cover A.
Current replacement drone has a manufacture date of 06/2022 and has gimbal cover B.
2022-7-13
GLOBAL HAWK
Flight distance : 287841 ft
THANKYOU!!!!! Completely agree. The maturity level in the mini 3 forum is childish low and starting to get quite pathetic. I got bagged out for being rude about common questions and this is another bu77sh1t POLL.
Lets start our own. " Can you make life choices yourself or do you need the rest of world to answer for you" YES or NO
FFS.............................
2022-7-13
Satureyes
Flight distance : 524908 ft
But see a point in commenting on a poll you don't see the point of.
Irony.
2022-7-17
Suren
Flight distance : 13641634 ft
Mine is Option B and I got my drone when the 1st batch hit New Zealand
2022-7-17
djiuser_WNMKvutofePI
Flight distance : 133110 ft
I wonder if Dji will make the upgraded, (easier to install) Version B Gimbal cover available as an add-on accessory that can be purchased?
2022-7-17
Bashy
Mine is B, i dont like the way the gimbal is able to move so i still use the foam.
2022-7-17
DAFlys
Bashy Posted at 7-17 18:40
Yes it seems to defeat the purpose if it can still swing around inside.    Does the foam fit snuggly or will it fall out if youre not careful?
2022-7-17
nosnoop
DAFlys Posted at 7-17 22:01
It cannot fall out if you are using the cover with the foam.
2022-7-17
DAFlys
nosnoop Posted at 7-17 22:25
I meant when you take the cover off will the foam fall out.
2022-7-17
Bashy
Its deffo snug, not gonna come out on its own. but yeah, purpose defeated to an extent, it prevents knocks  against it nut not too it, make sense? i know what i mean lol
2022-7-17
DAFlys
Bashy Posted at 7-17 23:03
Just saw your other post,  and I realised I didnt understand how the foam worked,  I had assumed it was inside the gimbal guard in places of the ribs that mine has.
2022-7-17
Sean-bumble-bee
Flight distance : 15997 ft
If the foam is fitted inside the cover and is in contact with the camera body when the cover is fitted to the drone I would be careful to keep the foam clean and free of grit, especially if you have a filter fitted.
2022-7-18
DAFlys
Sean-bumble-bee Posted at 7-18 00:52
I don't have the one with the foam,  I have the original one.
2022-7-19
BrianKushner
Flight distance : 45500102 ft
Option B and my drone arrived 2 days ago from B&H. It was made 06/22
2022-7-21
NewToy
Flight distance : 3440564 ft
tanasit Posted at 7-12 09:41
First thing to break off ,the sensor cover area
2022-7-21
Sree
I received mine on 7/19 with a gimbal cover A. The date on the box was 2022/5, I am not sure whether its manufacturing date or packaged date.
2022-7-21
The Saint
Flight distance : 6260171 ft
i must have missed this thread when it first posted few weeks back.
eventually dji will have to sell these since people do lose them.
2022-7-21
123Next >
