fansb4f50ec1
Flight distance : 13897156 ft
So my observations...
- The FCC/CE problem is fixed - no more rebooting to try to force FCC mode (I am in Canada).
- I have had obstacle avoidance stop working in N mode with 2.7K/30fps (I have never had this problem before).
- The small attitude indicator and compass map in the bottom left is not working as it did with the prior RC firmware. It now acts as if the controller is pointing in an entirely different direction than it is, and calibration doesn't change anything. This used to be a rock solid indicator of which direction the drone was in, but it's totally wrong now (by as much as 180 degrees) and jumps around a lot.
- (not fixed)... Wifi is still forced off but never automatically re-enabled. Syncing logs requires manually turning wifi on.
