Suren
Flight distance : 13728120 ft
New Zealand
JerseyJim Posted at 7-15 14:05
I did not answer the poll, because for 2 weeks mine did not work, then I figured out how to get it to work every time (Air 2S.)
It was the sequence in how I was starting the hardware, then the App. Every time I would activate it and leave the "advanced settings page", it would not be switched on when I went back in to check. I now start the DJI Fly app first, most of the way, and switch on the drone and controller. This now launches the Fly screen with live image, etc. Works EVERY time now, where it failed to do so a hundred times. now I go into the advanced features menu and the feature switch is ON and blue. Also, when I expand the map on the lower left portion of the DJI Fly screen, I always get the aircraft icon (below the layers button/icon) of the 5 other vertical buttons on the right side of the map. This button allows me to select the level of collision risk I want to detect. I alway select the "lowest risk" of the 3 choices. Without the feature truly turned on, you won't get this 6th airplane icon. I spent countless hours figuring this out, and posted about it 2 or 3 weeks ago.
That part works for me, Airsense is turned on with notifications set to the highest risk but i still get no notifications. Because i use RC Pro, I always start the RC first, then open drone up and power it on. No matter what i have tried it does not work. |
