KillerKingSSS
Mexico
Good to hear, then your data is there so maybe it´s just some conflict with windows assigning the letter.
What happens when you plug the camera in windows? Does the drive shows up in disk manager?
You can try:
Case 1. SSD Not Showing Up Because the Drive Letter is Missing or Conflicting
Sometimes, your SSD not showing up is because the drive letter of the SSD is missing or conflicting with another disk, and the Windows OS is unable to recognize it. You can solve this problem by manually assigning the SSD a new drive letter in Windows Disk Management.
To assign the SSD a new drive letter, follow these steps:
Step 1: Right-click on "This PC", select "Manage". Under the Storage section, click "Disk Management".
Step 2: Right-click on the SSD partition and select "Change Drive Letter and Paths…".
Step 3: Among Add, Change, and Remove, click the "Change" button, and then select a drive letter from the list. Click "OK" to confirm.
Case 2. SSD Not Showing Up Because It is Not Initialized
If you get a new SSD and it won't show up in Windows Explorer, it's likely in the "uninitialized" state. You must initialize a disk before Logical Disk Manager can access it.
Also, if an old SSD shows the "disk unknown not initialized" error, the reason is the same. In these two situations, to fix the problem, you can try to connect the SSD to another working computer to check if it reports the same error. Otherwise, you will need to initialize the SSD in Windows 10.
To initialize an SSD, follow these steps:
Step 1: Open Disk Management on your computer.
Step 2: Find and right-click the SSD you want to initialize, and then click "Initialize Disk".
Step 3: In the Initialize Disk dialog box, select the disk(s) to initialize. You can select whether to use the master boot record (MBR) or GUID partition table (GPT) partition style.
Case 3. SSD Not Showing Up Because the File System is Not Supported
If the above two methods do not work for you, you need to think further. One assumption is that the file system has corrupted or Windows does not support the current file system.
As investigated, the relevant file system issues are mainly displayed as 'RAW', 'Free space', or 'Unallocated space'. To fix the file system issues, reformatting the disk would be enough.
Note: Disk formatting will completely erase data on the disk. If you didn't create a data backup before, download EaseUS Data Recovery Wizard for FREE to recover data from the formatted SSD. |
