Confused about formatting compatability
9158 6 2022-7-20
paulf6
Flight distance : 10548 ft
Hi All - I just purchased a DJI Mini 3 Pro and am loving it. I'm confused about formatting the microSD cards. Using the controller, when I format the internal SD card, all is fine until I need to transfer the pictures I took with the drone to my PC, so I can process them in Photoshop. When I insert the SD card into my PC, I immediately receive a notice that tells me I need to format the SD card. Apparently, Windows 10 cannot read the photos I've created after formatting the SD card in my drone. Can someone please help me with what I'm doing wrong? Thanks. -Paul
2022-7-20
DJI Stephen
Hello there Paul. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try using a different microSD card to see if the issue will persist? Just a reminder that if the SD Card is formatted, the SD card that is less than or equal to 32GB should be formatted in to the FAT32 file system while the SD card that is larger thank 32GB should be formatted in to exFAT file system. Thank you.
2022-7-20
DowntownRDB
Flight distance : ****
I had a similar issue but after formatting the SD Card on my windows PC the issue resolved.  On my other DJI Drones I could format the SD Card in the drone and not have an issue.  Guess my Mini 3 is different.
2022-7-21
fansbfc83bb6
DowntownRDB Posted at 7-21 04:32
You've just described my problem perfectly. When I format a SanDisk 512 Gb micro SD card while it is inserted within my Mini 3 Pro drone and then take photos, my Win 10 PC is unable to read the card and tells me I need to format it. However, if I first format the card in my Win 10 PC and then take photos, my PC can see the photos I took and allow me to work on them in Photoshop. Thanks for your help. Paul
2022-7-21
DowntownRDB
fansbfc83bb6 Posted at 7-21 06:06
No problem Paul.    I'm just glad you got the issue resolved.  Happy flying!
2022-7-21
fansbfc83bb6
DowntownRDB Posted at 7-21 08:07
Many thanks!!!  :-)
2022-7-21
DowntownRDB
fansbfc83bb6 Posted at 7-21 08:50
Many thanks!!!  :-)
You're very welcome.
2022-7-21
