TheBoy
Flight distance : 28958264 ft
I'm a UK flyer, thus operate with CE power levels.
The Mini 3 remains a disappointment compare to the Mini 2 when it comes to signal integrity/reliability. Clearly DJI are aware (but won't admit) and messing with things like prioritising video feed over telemetry. But there isn't a busting lot of options within firmware, given the poor antenna layout. As dad used to say, you can't put a shine on a turd.
Whether or not it will actually impact you depends on local conditions and how you use it:
Rural, you are unlikely to have an issue, but the aircraft does seem to be quite directional, even when using the older RC-N1. Standard Battery will probably be the limit (about 6km each way), assuming you aren't doing a 1 way flight. But, then, in EU countries there are probably better options for rural drones, from DJI and others.
Urban is more tricky. I still get lots of video stutter at around 300-400m here, with frequent disconnections, which ruins any footage. I never get that with the Mini 2 in the same area, even if I'm not that careful with which way the transmitter is pointing. But every urban location is different. Certainly you need to obey CAA laws to the limit, as flying behind a tree or behind a house *WILL* cause a dropout if you are further than 150-200m... ...and the rules do say you have to always maintain VLOS. |
