Sean-bumble-bee
Flight distance : 15997 ft
djiuser_4l7wcJ9ItdqL Posted at 2-27 07:54
btw, what are you thoughts about this? it improves airflow,so it reduces heating the guy(dutch vidoegrapher) states it helps a lot, and this is a raw try out, done by a hot solding iron
https://www.youtube.com/watch?v=0yY6ACvxCdg
What overheats, the drone or the battery?
If the drone what part of the drone and where is it, above or below the battery?
Unless, because of those holes, air can circulates within the battery shell i.e. up through those holes and then out through the gaps around the battery clips then I imagine no significant gain in battery cooling. If there is circulation and hot air escapes around the battery clips where is that hot air going to go, can it reach the outside air without passing through the drone.
Battery warranty is almost certainly voided. |
