yjusot
Hello,
Same problem.
I try to update to firmware P3X_FW_V01.03.0020.bin without success.
I use the SD that comes with the Phantom P3Pro. I check twice that I downloaded the correct version for Pro model.
I tried severals times to upgrade, with the suggested notes from previous replies above, but nothing works.
I tried to format the SD from the mobile app, copy the bin in the root, launch the upgrade process (put the SD on the drone, and turn it on). Everything seems to work well but after 30mn: solid red light on the camera, and beeeeepppp in continue...
I tried also to format from the notebook, FAT32 to remove all, even hidden files...same result.
So after 4 attempts, 2 hours, I'm fed up with DJI Phantom upgrade...it never works like a charm...
Some ideas?
Thanks.
PS: I have also a TXT file (P3X_FW_LOG_AB.txt) in the MISC/LOG folder of the SD card.
Here is the content of the latest attempt:
[00013081]========== remo-con disconnect. boot(15) ============
[00013161]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xa0ce425e].
[00013236]Packet upgrade start...
[00013312]Packet checking...
[00013393]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013498]Done.
[00013570]Version checking[1]...
[00013727][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013883][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013964][04 00][00] v1.40.0.0 -> v1.40.0.0
[00014067][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014269][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00014436][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014683][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014838][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014998][12 03][00] v1.8.0.0 -> v1.8.0.0
[00015172][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015338][17 00][00] v0.0.0.0 -> v1.1.1.7 need upgrade.
[00015497][17 01][00] v0.0.0.0 -> v1.0.2.7 need upgrade.
[00015587][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015667][01 00][00] v1.23.3419 -> v1.23.3419
[00015742][01 01][00] v1.23.3419 -> v1.23.3419
[00015823][08 00][00] v0.12.0.4 -> v0.12.0.4
[00015896]Done.
[00017972]Waiting for user confirm...
[00028053]Timeout, start upgrade automatically.
[00028202]Firmware upgrading[1]...
[00028299][17 00] Firmware upgrade start...
[00223378][17 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 148, los = 114, ng = 0).
[00253462][17 01] Firmware upgrade start...
[00399987][17 01] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 100, los = 84, ng = 0).
[00430078][11 00] Firmware upgrade start...
[00540193][11 00] Firmware upgrade finished successfully.
[00540268]Done.
[00540338]Version checking[2]...
[00540498][03 05][00] v34.2.0.9 -> v34.2.0.9
[00540658][03 06][00] v2.2.6.19 -> v2.2.6.19
[00540742][04 00][00] v1.40.0.0 -> v1.40.0.0
[00540823][09 00][00] v1.7.0.3 -> v1.7.0.3
[00541024][11 00][05] v1.7.0.0 -> v1.7.0.0
[00541187][12 00][00] v1.8.0.0 -> v1.8.0.0
[00541358][12 01][00] v1.8.0.0 -> v1.8.0.0
[00541558][12 02][00] v1.8.0.0 -> v1.8.0.0
[00541728][12 03][00] v1.8.0.0 -> v1.8.0.0
[00541902][15 00][00] v1.1.2.0 -> v1.1.2.0
[00542073][17 00][00] v0.0.0.0 -> v1.1.1.7 need upgrade.
[00542233][17 01][00] v0.0.0.0 -> v1.0.2.7 need upgrade.
[00542323][19 00][00] v1.0.8.96 -> v1.0.8.96
[00542402][01 00][00] v1.23.3419 -> v1.23.3419
[00542485][01 01][00] v1.23.3419 -> v1.23.3419
[00542577][08 00][00] v0.12.0.4 -> v0.12.0.4
[00542652]Done.
[00542731]Firmware upgrading[2]...
[00542823][17 00] Firmware upgrade start...
[00752995][17 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 177, los = 116, ng = 0).
[00783170][17 01] Firmware upgrade start...
[00879498][17 01] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 26, los = 50, ng = 0).
[00909580]Done.
[00909655]Version checking[3]...
[00909767][03 05][00] v34.2.0.9 -> v34.2.0.9
[00909883][03 06][00] v2.2.6.19 -> v2.2.6.19
[00909970][04 00][00] v1.40.0.0 -> v1.40.0.0
[00910068][09 00][00] v1.7.0.3 -> v1.7.0.3
[00910224][11 00][05] v1.7.0.0 -> v1.7.0.0
[00910357][12 00][00] v1.8.0.0 -> v1.8.0.0
[00910568][12 01][00] v1.8.0.0 -> v1.8.0.0
[00910745][12 02][00] v1.8.0.0 -> v1.8.0.0
[00910898][12 03][00] v1.8.0.0 -> v1.8.0.0
[00911064][15 00][00] v1.1.2.0 -> v1.1.2.0
[00911237][17 00][00] v0.0.0.0 -> v1.1.1.7 need upgrade.
[00911397][17 01][00] v0.0.0.0 -> v1.0.2.7 need upgrade.
[00911527][19 00][00] v1.0.8.96 -> v1.0.8.96
[00911606][01 00][00] v1.23.3419 -> v1.23.3419
[00911680][01 01][00] v1.23.3419 -> v1.23.3419
[00911768][08 00][00] v0.12.0.4 -> v0.12.0.4
[00911842]Done.
[00911916]Firmware upgrading[3]...
[00912013][17 00] Firmware upgrade start...
[01008026][17 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 31, los = 52, ng = 0).
[01038119][17 01] Firmware upgrade start...
[01160403][17 01] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 86, los = 71, ng = 0).
[01190488]Done.
[01190568]Version checking[4]...
[01190725][03 05][00] v34.2.0.9 -> v34.2.0.9
[01190886][03 06][00] v2.2.6.19 -> v2.2.6.19
[01190970][04 00][00] v1.40.0.0 -> v1.40.0.0
[01191067][09 00][00] v1.7.0.3 -> v1.7.0.3
[01191263][11 00][05] v1.7.0.0 -> v1.7.0.0
[01191432][12 00][00] v1.8.0.0 -> v1.8.0.0
[01191593][12 01][00] v1.8.0.0 -> v1.8.0.0
[01191771][12 02][00] v1.8.0.0 -> v1.8.0.0
[01191936][12 03][00] v1.8.0.0 -> v1.8.0.0
[01192097][15 00][00] v1.1.2.0 -> v1.1.2.0
[01192236][17 00][00] v0.0.0.0 -> v1.1.1.7 need upgrade.
[01192356][17 01][00] v0.0.0.0 -> v1.0.2.7 need upgrade.
[01192487][19 00][00] v1.0.8.96 -> v1.0.8.96
[01192566][01 00][00] v1.23.3419 -> v1.23.3419
[01192721][01 01][00] v1.23.3419 -> v1.23.3419
[01192809][08 00][00] v0.12.0.4 -> v0.12.0.4
[01192889]Done.
[01192963]Firmware upgrading[4]...
[01193063][17 00] Firmware upgrade start...
[01264684][17 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 24, los = 43, ng = 0).
[01294775][17 01] Firmware upgrade start...
[01362512][17 01] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 22, los = 42, ng = 0).
[01392587]Done.
[01392661]Version checking[5]...
[01392816][03 05][00] v34.2.0.9 -> v34.2.0.9
[01392976][03 06][00] v2.2.6.19 -> v2.2.6.19
[01393071][04 00][00] v1.40.0.0 -> v1.40.0.0
[01393160][09 00][00] v1.7.0.3 -> v1.7.0.3
[01393356][11 00][05] v1.7.0.0 -> v1.7.0.0
[01393549][12 00][00] v1.8.0.0 -> v1.8.0.0
[01393705][12 01][00] v1.8.0.0 -> v1.8.0.0
[01393866][12 02][00] v1.8.0.0 -> v1.8.0.0
[01394034][12 03][00] v1.8.0.0 -> v1.8.0.0
[01394200][15 00][00] v1.1.2.0 -> v1.1.2.0
[01394370][17 00][00] v0.0.0.0 -> v1.1.1.7 need upgrade.
[01394570][17 01][00] v0.0.0.0 -> v1.0.2.7 need upgrade.
[01394680][19 00][00] v1.0.8.96 -> v1.0.8.96
[01394762][01 00][00] v1.23.3419 -> v1.23.3419
[01394837][01 01][00] v1.23.3419 -> v1.23.3419
[01394932][08 00][00] v0.12.0.4 -> v0.12.0.4
[01395008]Done.
[01395089]Firmware upgrading[5]...
[01395182][17 00] Firmware upgrade start...
[01457519][17 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 22, los = 35, ng = 0).
[01487605][17 01] Firmware upgrade start...
[01579527][17 01] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 45, los = 56, ng = 0).
[01609607]Done.
[01609685]Version checking[6]...
[01609790][03 05][00] v34.2.0.9 -> v34.2.0.9
[01609915][03 06][00] v2.2.6.19 -> v2.2.6.19
[01610003][04 00][00] v1.40.0.0 -> v1.40.0.0
[01610115][09 00][00] v1.7.0.3 -> v1.7.0.3
[01610270][11 00][05] v1.7.0.0 -> v1.7.0.0
[01610379][12 00][00] v1.8.0.0 -> v1.8.0.0
[01610550][12 01][00] v1.8.0.0 -> v1.8.0.0
[01610684][12 02][00] v1.8.0.0 -> v1.8.0.0
[01610899][12 03][00] v1.8.0.0 -> v1.8.0.0
[01611075][15 00][00] v1.1.2.0 -> v1.1.2.0
[01611199][17 00][00] v0.0.0.0 -> v1.1.1.7 need upgrade.
[01611341][17 01][00] v0.0.0.0 -> v1.0.2.7 need upgrade.
[01611435][19 00][00] v1.0.8.96 -> v1.0.8.96
[01611512][01 00][00] v1.23.3419 -> v1.23.3419
[01611593][01 01][00] v1.23.3419 -> v1.23.3419
[01611690][08 00][00] v0.12.0.4 -> v0.12.0.4
[01611770]Packet upgrade failed at firmware upgrade.
