DJI Please make Panorama mode next level!
1242 23 2022-7-22
Bussty
Flight distance : 320951 ft
New Zealand
Hi DJI
Having been away on a road trip for 6 days with the Mini 3 Pro I felt it was a little awkward capturing certain manual panos that I wanted. The Classic mistake for example is trying to do a 3 shot vertical pano and realising the middle shots have a lot less width than the top and bottom shots and I should probably have taken extra shots through the middle (just an example) also it takes time to capture a full 360 x 180 pano using the vertical mode to capture the top half then running the standard 360 x 180 Sphere mode and combining the two sets in something like PTGUI which by the way does a great job of combining the two seamlessly.
So I have a solution to both these problems in one Firmware Update.....   A Panorama Custom Mode with ability to store settings in a library you can quickly call up in future. Litchi does something similar with it’s Pano mode on Apple devices.
The concept is simple you have a custom screen with 5 settings. You can set these and save them in a library. The settings would be...
·        Horizontal or Vertical Lens Mode  (naturally) if you try and set a vertical range (below) that is higher than the Horizontal lens mode can capture the software would tell you.
·        Stitch Panorama or Don't Stitch Panorama - Many of us would opt for the later and stitch in something manually like PTGUI
·        Horizontal Angle (so for example a 360 x 180 full pano would be 360 degrees, but a smaller width pano would be less.)  you only need one setting here but vertical range is different.
·        Upward Vertical Angle (again for a 360 x 180 pano this would be set to +90 degrees. But for say a pano only capturing from the Horizon down to -90 this would be 0 degrees etc)
·        Downward Vertical Angle (again for a 360 x 180 pano this would be set to -90 degrees. For a pano capturing down to say -45 degrees you would just enter -45 etc)
With those 5 settings you would be able to easily capture any degree of Panorama really quickly using saved settings from the library which is the key to minimize movement of clouds etc between exposures.
The mode needs to retain whatever exposure settings you have set whether manual or auto so is just the function of manually moving the lens and taking the exposures.
I'm sure there is some pretty basic programming required to work out the required number of shots etc.
The ability to do this is already built into the Mini 3 Pro it just requires some additional programming and Firmware update.
DJI this would really support the Pro title and implied functionality of the Mini 3 Pro and I'm sure the still photographers here would support such a useful function allowing a roving drone photographer to quickly capture a very useful range of images plus solves your 360 x 180 True Sphere Pano Mode issue but hey if you create this it would be easy to update the current built in 360 x 180 pano mode to work properly using the vertical lens.
DJI looking forward to your support!
Many thanks
Bussty
2022-7-22
DJI Stephen
Hello there Bussty. Thank you for reaching out and for giving out these information and your valued insights with regards to this matter. This information will be noted and will be forwarded to the designated DJI Department for attention. Thank you and have a nice day.
2022-7-22
Bussty
New Zealand
Thanks DJI Stephen hopefully DJI will be able to make this happen :-)
2022-7-22
alex_markov
Flight distance : 39646480 ft
Bulgaria
Uau a true believer You are - they can't fix 360 pano to cover sky and You want them to make something so complicated - wish You luck! I'll settle for proper 360 for now
2022-7-22
Bussty
New Zealand
alex_markov Posted at 7-22 22:52
Hope springs...  :-)
2022-7-22
DowntownRDB
Flight distance : 1722 ft
Valid request Bussty.    Let's see if DJI decides to implement it.
2022-7-23
Bussty
New Zealand
Thanks Downtown I always complete the surveys when doing firmware updates and state this as my most important fix as DJI asks.
2022-7-23
WernerD
Flight distance : 350837 ft
Austria
I am using 360 Panos a lot, hence would appreciate the suggested feature as well.
2022-7-24
Bussty
New Zealand
WernerD Posted at 7-24 00:48
Thanks Werner
The more users DJI know would really value this feature the more DJI are likely to implement.
2022-7-24
SPLflyer
Flight distance : 144829 ft
Bussty Posted at 7-24 00:57
Thanks Werner
Have almost given up hope. But also from me an urgent "thumbs up"!
2022-7-25
Bussty
New Zealand
Thanks SPFlyer the more the merrier! I urge all pano users to keep this post live.
2022-7-25
Jann Lipka
Flight distance : 334058 ft
Sweden
Please improve panorama with proper zenith hole ( upper row )  !
2022-8-12
Bussty
New Zealand
Jann Lipka Posted at 8-12 05:13
Thanks Jann hopefully DJI are listening to this feedback for something that should have been part of the drone's functions from launch. Looking very much forward to that future Firmware update that allows this
2022-8-12
Montfrooij
Flight distance : 2560453 ft
That would be great!
2022-8-14
Bussty
New Zealand
Montfrooij Posted at 8-14 23:59
Thank you Montfrooij! Lets hope DJI engineers are listening
2022-8-15
Montfrooij
Bussty Posted at 8-15 00:18
I hope so
2022-8-15
weedhopper
Flight distance : 85686 ft
Don't dream, if they had wanted, they would have done it a long time ago...
2022-8-15
Montfrooij
weedhopper Posted at 8-15 00:51
We can dream.
They have added stuff afterwards long time after releases before.
2022-8-15
Bussty
New Zealand
Montfrooij Posted at 8-15 01:07
We can dream.
This is true...
2022-8-15
SPLflyer
I'm still holding out hope that DJI will at least implement a 4th row in the panorama algorithm, even if a hole inevitably remains at the top of the sky due to hardware limitations. But I'm afraid, what I've stated here https://forum.dji.com/forum.php? ... 948&pid=2815483 still applies.
Come on, DJI, jump over your own shadow – even if the result is not perfect! At least it would minimize the time lag that inevitably occurs between the Sphere Pano and the manual fourth row which causes stitching problems especially in cloudy skies.
2022-8-15
Bussty
New Zealand
SPLflyer Posted at 8-15 03:22
I'm still holding out hope that DJI will at least implement a 4th row in the panorama algorithm, even if a hole inevitably remains at the top of the sky due to hardware limitations. But I'm afraid, what I've stated here https://forum.dji.com/forum.php?mod=redirect&goto=findpost&ptid=270948&pid=2815483 still applies.
Well said Bernd. Lots of Mini 3 pro owners looking for this, DJI this will make the Mini 3 Pro a unique Sphere Panorama drone...
2022-8-15
Montfrooij
I only tell the truth
2022-8-15
Bussty
New Zealand
Montfrooij Posted at 8-15 03:43
This is a relief
2022-8-15
Montfrooij
Hahahahahahahaha.
You just have to believe me
2022-8-15
