frankymusik
Flight distance : 27507408 ft
DreamWorks Posted at 7-31 19:22
As per reply #27 that youre on about
For me, doing the calibration on its own failed to resolve the direction issue, i tried that at least 3 times, after the reset and one calibration later, it is now working great.
... what is important in this "procedure" for recalibrating the compass is to use the magnet when you are currently in "Settings" and "Compass Calibration" and you can still read "Compass normal" at the bottom of the display ...
Using the magnet without the DJI RC being powered on will not affect the accuracy of the compass reading in any way.
Likewise, it has no effect on the request by the DJI RC to recalibrate the compass if it is switched on but you are not on the described menu page in the "Settings"...!!!
Unless you are prompted by the DJI RC to calibrate the compass, you cannot force the DJI RC to recalibrate...
Even if the "Calibrate compass" button is always there, pressing it has no function unless the DJI RC has recognized that there is a fault...
Exactly this disturbance can be achieved with a magnet, as shown several times...
A friend of mine "told me" this "trick" a few weeks ago, but prior to DJI RC's FW .0300, this recalibration only worked for a few minutes, after which the known compass display glitching was back, so no permanent fix has been found...
As far as I know (and learned from others), the "Magnet Trick" works very reliably for everyone...
If you should have the need again, just try it again exactly according to the instructions I have described, then you may also be successful, like others...
I didn't understand your comments about the "credits". Should I commend you for managing to calibrate the compass in a different (more cumbersome) way...?
I read with you: "Germany", then "United Kingdom", then "Netherlands", etc. etc.
Does it automatically update your location when you log into the forum...???
