djiuser_7SMVn2eThqwk
Flight distance : 70669 ft
superCoolDude Posted at 2022-12-30 14:07
vxdanx, have you tried switching channels manually on the dji fly app? Depending on what kind of dji mini SE, one of them only supports 5Ghz but works well, and there is another one that uses 2.8Ghz too. The first drone isn't always intefered with, But you can change channels. Just go on Transmission on Dji fly app, switch from Auto channel switching to Manual switching, then pick a green bar on the chart below. The lower the bar height, the farther you can go, But make sure to check if the bar you want is green!!!! Then you will be
Here is some tips though. Depending where you live (I live where there isn't that much inteferance), no matter what, there will be inteference, so always make sure that there usn't that much trees, powerlines, and Wifi towers.
Is there a fix for this yet? My Mini SE was changed to manual mode now won’t pair with the controller. Mini SE is just blinking fast yellow. There must be a way to reset the controller with firmware. |
