HGDC84
Finland
HGDC84 Posted at 8-16 07:59
I am also interested in the DJI Mic and possibly get one later on. Just wondering if it works using the DJI Mic's USB-C adapter connected to the Pocket 2 (either directly of the DIA Handle connected) or if I will need to use the 3,5mm connector.
Would be great to be able to use the Pocket 2 creator combo's wireless mic and the DIA Handle's USB-C or 3,5mm connector for a microphone at the same time too, but as far as I know this is not possible, at least not on current firmware.
Got the DJI Mic and tested it out. You have no other options with the Pocket 2 except to use either the DIA Handle's 3,5mm connector or the Osmo Pocket 3,5mm to USB-C adapter. Direct connection through USB-C is not supported. It's not even physically possible to attach the receiver when using the Pocket 2's tripod mount adapter.
Also checked connecting the receiver to the Pocket 2 while trying to figure out a easy-to-handle and portable setup for both of them. Having the phone clip but NO PHONE ATTACHED helps, when having the receiver connected to the cold shoe if the clip with its adapter, after that just connect the DIA Handle and the cable from the receiver's output connection to the DIA Handle's 3,5 mm connector. However, if you don't have the DIA Handle attached and have a phone connected, you will need both the Osmo Pocket audio adapter and a longer cable, as the one supplied with the DJI Mic is not long enough.
Slightly miffed, but I will live. |
