Bashy
Flight distance : 2354357 ft
Dirty Bird Posted at 8-8 01:33
The DJI RC incorporates two tiny, internal, flat panel antennas, so I would expect it to be more directionally sensitive than RCs using omnidirectional antenna. If you have an Itelite flat panel antenna, you deal with the same situation.
I've only flown my Mini 3 a few times, but did not notice it to be overly sensitive to how it was pointed. I was extremely impressed with the range. 27,041' on the maiden flight. Signal was still good but the battery (plus model) was at 57% so I turned back. Arrived home with 23% remaining.
Good to hear, that will be the FCC doing its part, i have managed a few meters off 5.5km (18045ft) in CE, that's only cause of it disconnecting within a few seconds and initiating RTH, it did that 3 blooming times, so on the 3rd time i just brought it back, next time i will go higher, i was only at 30m (99ft).
Your 8.42km is pretty good even for FCC |
