Silver4K
Flight distance : 4783 ft
Brazil
If you are experiencing a "motor overloaded" error message on your DJI Mini 3 Pro drone, it typically means that the drone's motors are being strained, and they are unable to perform as expected. This can occur due to several reasons, including:
-Overloading the drone with heavy payloads: If you have attached any heavy accessories to your drone, it can put too much strain on the motors, leading to an overload.
-Flying in windy conditions: Strong winds can make it difficult for the motors to function effectively, leading to an overload.
-Using incorrect flight modes: If you are using the drone in sport mode or other high-performance modes when conditions are not suitable, it can result in an overload.
To resolve the issue, try the following steps:
-Remove any heavy accessories attached to the drone.
-Avoid flying in windy conditions.
-Make sure you are using the correct flight mode for the conditions.
Check for any firmware updates for the drone and make sure it is up-to-date.
If the issue persists, contact DJI support for further assistance. By ChatGPT |
