Huginn Kenningar
Flight distance : 49635259 ft
Disable OA, it's definitely the cause of this. It will interfere if you want perfectly smooth footage when you are that close to the ground (and even higher when it picks false positives).
Brake mode works to do a general flight, or if you are exploring, doing photos or using the drone for things like inspections. But if you want smooth video footage and a perfect flight path you need to temporally disable OA and make sure you are feeding the drone with perfect signal. This is less than 200m from the drone, direct unobstructed line of sight, the controller pointed towards the drone, FCC mode and the smartphone in airplane mode. In any other condition, you are introducing variables that will lead to various problems and the results will vary.
OA off, drone near, controller pointed, that's how drone videography is done. On photography on the other hand you can bring the drone to whatever distance you want because having bad signal or OA giving false positives from now and then means nothing.
PS: Furthermore, you can also play with the controller settings on the different modes and change the sensibility and smoothness, so it filters the movements you do on the sticks to perform a smoother trajectory.
