djiuser_oUMOHeV7ROec
Hi,
I'm experimenting an issue using MSDK RTMP streaming function.
The problem is that the latency increases from 5 second at startup to 1 minute after 30 minutes of streaming. I stream using the MSDK RTMP functions.
With my application the problem only appears when the application is restarted without rebooting the RC. Stream bandwidth seems to double after app restart, and increased latency appears.
With the DJI SDK Sample application, the increase in latency seems to be present every time. I start the stream from the "Live Stream" view of the application.
I use an M300 RTK drone with a smart radio.
DJI SDK Sample version is 4.15.1.
Have you ever experienced this kind of problem? Is there a way to correct the problem on my application ?
Thanks in advance
