rayrokni
Flight distance : 8139875 ft
ron.armes@gmail Posted at 2015-8-8 03:47
I had the same problem which I had never had before, then realised that I had not set the iPhone t ...
Ok, update:
I uninstalled the new DJI GO app and reinstalled it on my iphone6+. I took it out today, an overcast not crazy hot day.
Started RC, p3, the app took off and straight away disconnected sign, so I flew around LOS, it kept connecting and disconnecting. 2nd battery, took off the life proof case, in case it was overheating in the case, same result. 3rd battery, I came to the forum and looked up my thread, and saw the airplane mode on phone reply from you. I had always left that on with previous DJI pilot app and never had any problems, I know it is advisable to do that but since I never had any issues b4 I was reluctant to change that, but since this issue was driving me crazy, I know it is a short drive!!!, I turned airplane mode on and flew third battery, well I be ....., no disconnect problems at all. 4th battery, btw, all the flights were at exact same location, flew like a champ and no disconnect at all.
So, I will keep you guys up to date as to whether that has solved the problem or not.
Thanks to everyone for your inputs, I'll buy you lunch if I ever see you guys around. |
