DJI Susan
Hi there, thank you for reaching out. Regarding your first inquiry, DJI Mini 3 Pro is designed without a built-in fan, which can effectively reduce power consumption to make the flight time longer. Additionally, the new structural design with propellers that have been adjusted for a more aerodynamic flight, which allows the drone to use the wind generated by the propellers to dissipate heat, ensuring good heat dissipation effects during the flight.
If the drone stays in standby mode for a long time, its temperature may continuously rise. DJI Mini 3 Pro comes with a built-in temperature control system that the drone can detect the current temperature and decide whether to automatically power off to prevent overheating.
For the second issue, if the drone and DJI RC are purchased from the UK, and you are located in the UL, please purchase the UK's version of DJI Care Refresh, the checkout currency should be in pounds. Please do not purchase the US version of DJI Care Refresh. Because the DJI Care Refresh and the product should be purchased from the same country/region, the benefit will be only eligible from where the service is purchased.
Hope these clarify your concerns. Thank you for your attention. |
