I have tried the steps mentioned in previous discussion. The pairing times out without connecting. This is an old RC 231 that was the original controller for a Mavic Air 2 that was destroyed. I never used it to control the replacement. So it is not paired or bound to any existing device. Is it going to be possible to use this RC 231?
Hi Clemlaw, sorry for the issue. Please double confirm if the mobile device has been connected successfully, if the time-out prompt popped up immediately after pressing the linking button on the app without counting down, the mobile device is not connected to the RC, please check the connection.
If the mobile device is connected to the RC, and linking does not work, please make sure that the firmware for the RC and aircraft has been updated to the latest version. Please try to refresh the latest firmware for the controller and aircraft via DJI Assistant 2 and try to link again. The linking tutorial can be checked at 7:05 of this tutorial:
Please keep us updated if the issue persists, an operation video of yours is appreciated.
Thank you. The timer runs and repeatedly times out. The problem is that since the contoller is not linked to an aircraft and the Mini 3 pro isn’t linked to a controller it’s impossible to update the firm ware on either one.. Is it possible to overcome this with DJI assistant 2?
Clemlaw Posted at 8-3 19:43
This video, from 1:50 to 2:20, will show you how to update the Remote controller.
Thank you for your update, if you would be able to use a computer to do the firmware update, the controller can be updated respectively.
Please download the DJI Assistant 2 software on your computer (tap here for the software link), and refer to the tutorial posted on 4# and update the firmware. Please let me know if that solves your case.
DJI Assistant 2 won't open on my MacBook Air running OS 12. On my PC it downloads but opens with a single screen that shows a diagram of hooking a USB to an Inspire 2. There are no other menus available.
Clemlaw Posted at 8-4 03:40
Be sure to download the right version for the Mini 3 Pro. You should be using DJI Assistant 2 (Consumer Drone Series) v2.1.10 from here. You may need to run it from your PC.
Thanks I managed to get around the blocks on the Mac and was able to update the controller which then paired easily and operated the Mini 3 pro without problem.
Operation of DJI Assistant2 in OS could use a little smoothing out. I got it to work once but now it opens a page that says welcome to electron and following the directions on the page won’t open the app.
Clemlaw Posted at 8-4 12:23
Hi, there. Thanks for your update. May we double confirm that your issue has been resolved, right?
Hey Clemlaw, please share how you got assistant 2 to work on your Mac, I am having EXACtly the same problem as you. Thanks so much.
The key was updating the controller. I’m sorry but it was one of those late night computer things where I just kept pecking away at it and I couldn’t tell you the sequence.. I can say don’t worry about the drone. Your just try to get the updated firmware on to the Controller.
That means there's no way to update the RC231 firmware?
Hello, there. Sorry for your inconvenience. Currently, all versions of DJI Assistant 2 do not support v11.0 or higher versions of Mac OS(Except DJI Assistant 2 (Consumer Drones Series)), because DJI Assistant 2 rely on the third-party RNDIS drive but the RNDIS drive does not support v11.0 or higher version of Mac OS. We will keep an eye on the latest updates. Once the RNDIS drive is compatible with v11.0 or higher versions of Mac OS, we will work on the compatibility of DJI products as soon as possible. Would you please upgrade the firmware on a PC with Windows software?
DJI Wanda Posted at 8-5 00:48
Hi i am having the same issue and is causing a lot of problems I need this drone today for the entire purpose I bought it for. Saw on another thread that admins can approve a new firmware upgrade to my account can you do this please?
djiuser_mpcVPNOyw7Yp Posted at 9-20 11:28
Hello, there. Sorry for your inconvenience. May we know if you are also trapped in pairing with the aircraft?
Hi, there. Sorry for your inconvenience. Just for double checks, may we know the model of your controller and drone? Could you please try to connect the drone to the DJI Assistant 2 to update the firmware to see if it works?
DJI Thor Posted at 9-21 23:13
Drone mini 3 pro with controller for phone connection. Drone won’t even flash lights to say in pairing most of the time. Tried using the assistant but nothing for the drone doesnt even show a connection. Was able to refresh the controller but no change.
djiuser_mpcVPNOyw7Yp Posted at 9-22 21:56
Sorry for the issue. Would you mind providing a video of your operation steps for the linking, the screenshots of the controller firmware and aircraft for me to confirm it further?
The firmware information can be checked after connecting the aircraft and controller to the DJI Assistant 2.
Look forward to your reply.
