Is Samsung Galaxy Note 10 lite compatible with Dji OMA 5?
729 1 2022-8-4
BigKnight
thank you so much
2022-8-4
DJI Stephen
Hello there BigKnight. Good day and thank you for reaching out. After checking the mobile device ( Samsung Galaxy Note 10 Lite ) that you want to use on your DJI OM 5 and on the DJI Mimo application. I am sorry to say that the mobile device is not yet recommended for the DJI application. DJI suggests using a recommended mobile device for the DJI Mimo application for compatibility and reliability purposes. There is a possibility that the Samsung Galaxy Note 10 Lite will be able to work on the DJI Mimo application. But however, since it's not yet optimized with the said DJI application we cannot guaranteed if it will work all the time and if it will be able to run all the functions of the DJI Mimo application while using it. For reference I will post a link where in you can check the recommended mobile devices for the DJI OM 5 ( https://terra-1-g.djicdn.com/851 ... ibility_List_en.pdf ). Thank you.
2022-8-4
