DJI Support
Flight distance : 2408 ft
Overview:
- Date: 2022.08.05
- Firmware: v01.03.0200
- Video Transmitter Firmware: v01.04.0100
- High-Bright Remote Monitor Firmware: v01.04.0100
- User Manual: v1.2
What’s New?
- Added ability to record and playback the transmission image and audio for the High-Bright Remote Monitor.
- Added support for up to 1080p/60fps HDMI signal display input for the High-Bright Remote Monitor.
- Added support for anamorphic display de-squeezing for the High-Bright Remote Monitor.
- Added HDMI/SDI output frame rate individual settings for the remote monitor expansion plate.
- Added HDMI output audio ability for the remote monitor expansion plate.
- Added ability to mark the focus points and limit points for Three-Channel Follow Focus.
- Fixed issue: Ronin 4D transmitter occasionally failed to start linking in a low-temperature environment.
Notes: - Attach all the accessories to Ronin 4D before updating firmware.
- Attach the DJI Three-Channel Follow Focus to the High-Bright Remote Monitor to update firmware simultaneously.
- Make sure to update both the Video Transmitter and High-Bright Remote Monitor to the latest firmware version. Otherwise, the video transmission may work abnormally.
- If the update fails, restart the device and try again.
