SFO-sanjay
CloudVisual Posted at 8-8 00:35
When you swap to D-Log it becomes a 10-bit colour profile which your software may not support. You will need to investigate if PD supports 10-bit h.264. Personally I would recommend swapping to h.265 first and seeing if that works. Also, ensure that your software has all available codecs installed and updated.
Thanks for the reply. Yesterday I found that the software does support if I switch to H.265. I still don't understand how come 10-bit H.264 does not work while 10-bit H.265 works. Anyway, problem solved. |
