Sean-bumble-bee
Flight distance : 15515 ft
Are you certain the ceiling was a 20m and not 30m?
There are various height limits imposed depending on whether or not GPS is available and or if VPS is available, these are detailed in the manual.
https://dl.djicdn.com/downloads/ ... Manual_v1.2_enI.pdf
There may also be height limits imposed if you are not logged into the App but I am uncertain about that so you would need to google it.
As Bleriot53 says the drone has no knowledge of its ASL and is concerned with only its height above the level of the take off point.
However, I would draw to your attention the fact that wind speeds tend to increase with height above the ground. As such setting a height limit of 400ft and presumably using it, is perhaps unwise. For flat land flights my max height, with any drone is normally under 60m, I mix units a lot.
The mavic Mini is not the best drone in wind.
Equally, unnecessarily high RTH's run the risk of putting a Mavic Mini up into high wind, they also waste battery power in the ascent and most noticably, if you are battery watching, in the descent. My normal RTH height is 25m to 30m, to avoid trees.
BE VERY CAREFUL when setting height and distance limits in the FLY app, it is VERY easy to accidentally change one when setting another, I know this from practical experience. |
