Sean-bumble-bee
Flight distance : 15997 ft
Whilst I think flying to that height was beyond stupid I have to ask, why, with the throttle fully closed, did the drone descend at ONLY 3m/s ?
The manual ( versions 1.0 and 1.2 ) and the specs webpage
https://www.dji.com/uk/air-2s/specs
state
Max Descent Speed 6 m/s (S Mode)
6 m/s (N Mode)"
That is published in versions 1.0 and 1.2 of the manual.
The fastest speeds where around 11m/s so the drone was not in cine mode.
If the quoted descent speeds have been incorrectly publish and it is ONLY teh sports mode that has a descent speed of 6m/s I am a bit puzzled as to why you did not switch to sports made to get a higher descent speed.
Post #40 implies that you are no stranger to high flights which also means that you are aware it takes a long time to get down from height. If 3m/s is the normal descent rate of previous high flights I would have thought that you could have estimated how long the descent would take to get down, I assume you work and fly in metric, 8657.8ft = 2638.9m, @3m/s that is, I think, 14min 40sec of descent time and it took you around 8 &1/2 minutes to get up there.
If, with the Air 2s, you previously have had faster descent rates than 3m/s then why didnt you do what ever it was that gave you those faster descent rates?
I believe the drone has, or should have had, around 20 days warranty left and if those quotations are correct then I would have thought there was an argument that this might be considered a warranty issue......BUT, to break the 500m ceiling, I would guess the drones's firmware has been messed with which will probably invalidate the warranty. |
