The battery will not charge. When pressing the power button the LED farthest away from the power button will flash 6 times. The battery was last flown this past Saturday and has been kept cool inside of the house since then. Have left it on the charger for 4+ hours with no signs that it wants to charge. Sounds like me and many others have dud batteries.
DJI can I get a replacement? Way unexceptable that an expensive battery like this cant make it a month aft at most 10 flights.
Hi there. Thank you for reaching out and we're deeply sorry to know the issue that you experienced. In this case, we strongly recommend coordinating this with our team by contacting them at https://www.dji.com/support. Thank you for your understanding and support.
DJI Paladin Posted at 8-9 21:16
2. If you are using the battery manager, you can try to use the direct charging charger.
If you still meet the same problem, you can use this link to start a case: https://www.dji.com/support/repair
And we will follow your case as well, please don't worry.
