Mike Prince Posted at 8-14 05:40
Hi - Tanks for the update.
I noticed the Vision Sensor icon remained red until the aircraft was in flight, the vision sensor icon is now appearing in white, I am guessing this is how it should be? Should it not be green?
Please note that DJI Mini 3 Pro will disable vision sensors when it is on the ground to reduce power consumption. When the aircraft takes off, all vision sensors will be enabled. Please feel free to use them. As for the subject scanning function, the aircraft needs to be in the take-off status to turn on this function (the function cannot be used even if start the motor only). The subject scanning function is only supported in single shot (photo mode) and normal recording mode (normal video mode), other modes are not supported, so it is recommended to try it in single shot and normal recording mode.
