Labroides
Flight distance : 9991457 ft
This drone keeps disconnecting less than 200 ft away from the controller and initiating RTH.
Looking at that flight data, you are getting a lot of indications of weak signal, a few times at 200-300 ft, but much more often at 800-1000 ft.
Each red dot on the Google Earth image below shows where this was happening.
There were no tall buildings or power lines or anything causing interference.
Interference in the flying area can be the cause of poor signal.
Before deciding that there's a problem with the drone/controller, you need to identify whether there might be an issue with the environment you fly in.
You mention flying this new drone 5 times.
Looking at the site in the flight data you posted, it has a large number of houses around your site, probably putting out a ton of wifi interference.
The further you fly into this, the signal dropouts increase.
Have you flown somewhere with no/low signal interference?
A flight just to the west would be a good test flight to see if there's a big difference and help understand if the problem is with your equipment or it it's due to interference in the local environment.
Another thing to consider is that the drone has the ability to use frequencies in the 2.4 GHz and 5.8 GHz bands.
If you are getting interference, sometimes switching to one or the other can help reduce the effect on your flight.
