sbonev
Flight distance : 3665279 ft
Bulgaria
hallmark007 Posted at 8-17 14:31
It has happened with mini 2 and I also read it here, I tried to look for that thread but couldn’t find it. It doesn’t happen all the time as I said and this is why it’s advisable to check after FW updates. There are many threads on Mavic Pilots also many articles online. But its a fact settings should be checked after updates.
Yes Im sure they could do better, and they have become less, today there was an update particularly for panos I expect this had something to do with it resetting.
If it happened once it does not mean it is normal, you realize that??? And changing the panos should not reset all other settings. It does not make any sense. And if I understand that all can happen, such things should be taken care before releasing to public, it is really unprofessional. Or at least they should make it aware by explicitly stating it. I don’t care if I have to set the settings again, but when they ruin some good shots and you cannot set them at home it’s really annoying. |
