DJI MIc not working on Iphone 13 or iPad (lighting connection)
12Next >
52536 56 2022-8-18
fly.overflying
Hello,
I need some help if there is any aditional setup to have the DJI mic to work with the iPhone and the iPad, I am not getting audio from the DJI mic after connecting it to both devices.
In order to get audio on the video application should I push recording on the microphone as well?
Is there any adtional iphone and ipad sofware configuration for this to work? I am trying to record in Mono.
2022-8-18
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the inconvenience caused. Can you please try to use a different Lightning adapter to see if the issue persists? Please note that you need to be connected directly to the bottom of the receiver using its expansion port. The receiver can then be attached to an iPhone. Kindly please refer to the tutorial link below for your reference. Please keep us posted. Thank you.
2022-8-18
fly.overflying
DJI Paladin Posted at 8-18 18:43
Thank you for the response.
If I use any other video application other than the stock iPhone / iPad camera application it works. I also tried 2 different iPhones and I am experiencing the same behavior, that shows the issue is not related to the lighting adapter.
Also it works when I connect to my laptop USB port.
All 3 iPhones and the iPad I used for testing are running the latest IOS, when I plug the lighting cable the volume controller toggles to a headphone, I am wondering if the iPhone needs to be on flight mode for this to work? Perhaps I tried and it didn't work. The 3rd party video / camera application that works seamless is Filmc Pro.
It has to be something on the configuration that has not been explained at any of these video tutorials.
2022-8-18
DJI Paladin
fly.overflying Posted at 8-18 21:13
Thank you for keeping us posted. Can you please send us a sample video showing the issue for us to check it here on our end? Please keep us posted. Thank you.
2022-8-26
mfangler
Flight distance : 7359 ft
It seems the issue on mine is the C connection lead to the Ipad and the sound does not work.
With other app software however with the same lead into the Ipad works i.e FILMIC so this must be a software fix.
The problem occurs only when I use the native Ipad camera where the software blocks the audio.
As I want to use the native Ipad video as I use it as an autocue, this problem definitely needs an urgent fix DJI.
Works perfectly with IOS phone and Lightening connection cable.
2022-8-26
fans9c28ffe7
Hi. I'm having the same problem. After connecting the expansion port and attaching it to the bottom of my phone, the icons indicate that it is plugged in. But when I record, the transmitter receives the sound but it doesn't get recorded into my phone. I detach the devices and when I playback the video, there is no sound. Am I doing something wrong here?
2022-9-8
fly.overflying
fans9c28ffe7 Posted at 9-8 22:43
Sorry to hear you are having this issue. I ended up sending it back and getting a refund. I may buy it back again when it is ready for use, if it will!
2022-9-10
BennySantiago
fly.overflying Posted at 9-10 21:35
Hi, did you ever get the issues fixed?
2022-9-15
Rosakatten
Flight distance : 2825 ft
Sweden
I got this mic as it would work so easily on 3.5mm and lightning on iphone...
Turns out it will not record sound to iphone to bad it says so in videos and in the DJI adverts.
Does not work!
2022-9-23
Rosakatten
Sweden
Rosakatten Posted at 9-23 01:25
Does not work!
Any one know why Dji won't fix this huge issue?
Disappointing is no understatement
2022-9-24
djiuser_zQcfWBAi5yTk
Flight distance : 226109 ft
Colombia
El micrófono no funciona con el IPAD PRO. Ya probe de varias formas y aun sigue sin funcionar. Aclaro que soy usuario avanzado y tengo 7 micrófonos distintos debido a que creo videos de forma profesional. Me gustaría que corrigieran este defecto ya que no son baratos estos gadgets.  Mi canal es www.TikTok.com/@jorge.amin .
Agradezco la ayuda que puedan brindar. Saludos.
2022-9-24
Rosakatten
Sweden
Rosakatten Posted at 9-24 11:20
Seems that it works if the adapter is placed correctly.
I tried a few times to remove and reinstall the adapter for lightning, and it needs to be just right.
Now it works!!
if it doesn't work remove and install the adapter again, just so it clicks in.
2022-9-26
Hi all, here is how I resolved this issue:
When listening to your iPhone Camera app recorded video with audio from the DJI mic, you need to unplug the DJI receiver first (otherwise your iPhone thinks it is a headset and you will not hear anything).
Simple as that!
Greets from Berlin,
Martin
2022-9-28
fans56c85470
Hi, could you tell me if the mono problem is resolved? I'd like to buy these mics, but if I cannot have stereo on my iphone I will buy Rode, its' simple!
It should work from scratch, not after buying other cables or tools. For 329€ Dji must offer a complete solution!
2022-9-28
djiuser_iCaVIVxiaRWi
Israel
Hi having the same problem- with iPhone.
recording without sound.
somebody can help with that? or is this not fixbule?
2022-9-29
fans258b7bab
DJI when will you fix the issue with the DJI Mic and iPads?
Why does it not work on iPads. Other mics I use work on the iPad?
Please advise as this is a MAJOR flaw in your usb-c protocol communication in your firmware!
2022-10-1
robbarrettjr
I've used it in the past without any trouble but today there was no audio recorded on the video even though there were levels showing on the receiver.
A window had popped up when I plugged in the receiver asking if this was a headphone or other. I said yes but probably should have said other.
The only way I could make it work was to launch the camera app and THEN plug in the receiver. Then audio was recorded. Strange.
This product has been one of my favorites. I was touting it's ease of use right before the shoot so I probably jinxed it.
If anyone knows how I can reset that hot shoe on my phone I would appreciate it.
2022-10-5
djiuser_mdRJ5hYQjnea
I’ve bought 2 of these mics after the first one had this issue as well. This new one worked for a single clip and now won’t record any audio - this is ridiculous, I think Rode Go might be the way forwards unless DJI sort this asap considering their device doesn’t work with the most popular phone brand in the world
2022-10-6
databurst
I also bought 2 of these systems and they both did the same thing with my iPhone 13 Pro, no recorded audio using the iOS Camera app.
Shout out to user mfangler who pointed out that sound works when using the FILMIC Pro app which I was able to confirm. That points the finger at the iOS Camera app.  Because of the dorky non-stereo recording via the lightning adapter, I switched the setting in the Camera app to turn off "Record Stereo Sound".  Tested it again, and it now works for me.
If you would like to try this workaround, do these steps:
1. In your iPhone, open the Settings app.
2. Locate Camera in the list and select it.
3. Be sure the option Record Stereo Sound is in the OFF position, or slider to the left and grayed out.
In my opinion, this doesn't give DJI a free pass to blow off this issue using this workaround as a solution.  DJI needs to make a working lightning adapter in stereo if they want to be considered on par with competing products.  I have been using the MOVI wireless lav solution which uses the Lightning interface and it works just fine in the Camera app set to stereo.  If DJI can sort this with stereo working on iPhone, then it would look like an attractive next step up product for us creators.
2022-10-9
SamShea
I think someone may have suggested this, but this is what worked for me.  If you start the video recording application on the iPhone first and then plug in the receiver it works.  Hopefully, this helps someone.
2022-10-12
SamShea
robbarrettjr Posted at 10-5 11:55
Thanks, your solution worked!
2022-10-12
ro_walker
Brazil
Very frustrating!
2022-10-30
djiuser_4tZzXbMIrYbG
Found this solution on reddit and it worked for me:
100% your jack is just not siting right. take it out of phone and push as forward as possible. then in to iPhone. also you can turn your mic on or off through the record screen button from the pull down from top menu. it looks like black and with target
so try jamming the lightning adaptor into the dji receiver. not ideal but maybe a fix.
2022-11-2
Pastor
Hello everyone
I bought this over 1 month and been using with my DSLR with no issues, and also tried with my iPhone 11 once received.
The issue I have now is when connecting to any iPhone I see a "Device not supported" error, and after some seconds, the mic stops working. Already tried on iPhone 11, 13 Pro, SE... And nothing works.
If I press the record button once connected, I can record the sound, until it stops after a few seconds.
Do you think I have a faulty product?
2022-11-4
caaza
Pastor Posted at 11-4 09:28
Hello everyone
The Dji Mic does not work with the iPhone :/
2022-12-14
caaza
The DJI Mic does not work  with the iphone Camera.
I've tried with an iPhone 11 Pro and an iPhone 14 Pro.
This is upsetting.
It works well when using the Dji Mimo app to record.
2022-12-14
djiuser_s72UZUYaLdXq
Flight distance : 71037 ft
What a mess, it does not work on an iPhone 8, iPhone 12, iPhone 13, the connection does not fit on a dji osmo action cam3 and the cable connection does not fit on a Nikon 3200. if you want to use it, you have to remove the receiver  let it dangle from the cable.  this was not expected.  Tried all suggestions above but nothing works.  Even with the Nikon it stops recording after 20 seconds.  I am very disappointed in this expensive non-working product.  my set will go back to the store anyway.
2022-12-23
polymerjones
Hey everyone on this post,
Oh my goodness. I was literally about to click Buy on this mic when I found this forum.
I have an iPhone 14 Pro Max.
Has this issue been resolved? or is this still a nightmare getting to work?
Are you able to record the two mic inputs into the iPhone simultaneously?
2023-1-8
Sharesnacks
djiuser_4tZzXbMIrYbG Posted at 2022-11-2 10:17
This did it for me. I was doubtful, because it threw no errors that it wasn’t connected properly.
Thanks!
For others, you have to push the adapter so it is just past flush with the receiver….but just before it complains (obvs) that the adapter isn’t connected. (See pic)
2023-1-9
Cleona
Just to chime in on this--the tip to push the adapter all the way so it is just past flush (as far as it goes, really) is what worked for me.
I have an iPhone 14 Pro max, and didn't have to do the extra things such as hit record first, or turn off the 'record stereo sound' option in settings. Also worked great with two mics.
Whew!
2023-1-21
Motivity 2
This is definitely a problem.  Did everything suggested but the ONLY thing that worked was to TURN THE TRANSMITTER AROUND.  I made the meters point backwards and it suddenly worked.  I have a few of these so I know it’s not my iPhone 14 pro because one set works perfectly and another doesn’t work.
2023-3-9
Motivity 2
As a follow up after recording with the transmitter backwards multiple times the front facing began to work.  No idea what’s going on but it was consistent with multiple iPhone 14 pros.  Very very finicky.  Can’t rely on it if you actually want to do an interview.   Like flipping a coin.
2023-3-9
Canaussie
djiuser_iCaVIVxiaRWi Posted at 2022-9-29 01:05
I followed the advice of a previous poster. Simply remove the lightning adapter and install it again. It should be all the way into the receiver. You can listen to the playback by removing the receiver from the phone or by using a bluetooth connected headphone.
2023-3-14
caballerocanari
The never fix it, I have the same problem, bought this expensive MIC and it don't works with iPhone! Dji sucks, never ever buy anything from them! Rode is much much better!
I think DJI gives a .....
2023-3-26
cjTc1yySFkA2
Same here. It did work well.the first time I used it. But only once. Now, the iPhone never record the sound anymore. I need to record on the transmitter and sync on my laptop.
The device still works on my MacBook Air, with the usb c port. But not anymore on my phone. Is the device trouble ? Do I need to send it back to get a new one from DJI ?
What I need to do, because this is pretty useless as is..
2023-6-1
cjTc1yySFkA2
caballerocanari Posted at 3-26 10:34
Witch rodes are you using to replace the DJI mic ?
2023-6-1
mdw302
mfangler Posted at 2022-8-26 02:45
I am having same problem also. I have iPhone 13 Pro Max. When I plug in the lightning adapter, I do not get the display that shows lightning connection is activated. I cannot not record a video using sound from this mic.
2023-6-6
mdw302
djiuser_s72UZUYaLdXq Posted at 2022-12-23 08:15
It does! I had the same issue at first. On the transmitter there are two sets of four gold dots. On the iPhone adapter there is one set. It has to line up correctly. I played around with it and I used a video app (Move Pro) which registered the mic as a headset, but I could see the volume bar go up and down on the video and on the transmitter. It works fine now - but those gold dots have to align.
2023-6-6
brian.donohue
the mic worked great with the iphone 14 for me for a few weeks, then just stopped. I got a "device not compatible" message and then it just stopped working. I tried every solution posted here - pushing  in the adapter, trying to use Filmic Pro, you name it. Nothing works. Very very disappointing.
2023-6-14
djiuser_qeXklz3h3DJH
fans9c28ffe7 Posted at 2022-9-8 22:43
Me too. You get a fix?
2023-6-24
12Next >
