Shorse
Flight distance : 162238 ft
WARNING TO ALL DJI MINI SE USERS!!! I got a DJI mini se about a week in a half ago and i am now on my 3rd one! If you go to trassmission and you switch to the manuel mode and swich to the last channel (this may be only for FCC model as that is what I have) the drone's wifi will restart as normal for swiching channels but the drone will never reconect to the controller as it should. If you contact suport they will tell you to put the drone into pairing mode and the controller will enter pairing mode just fine but the drone will beep once but the charging lights will not blink in sequence as they should rendering pairing mode useless. Next support will tell you to update your drone with the DJI Assistant 2 but this will not change anything! Finally they will just tell you to attempt to get a replacement as there is no fix for this problem. If this problem has occured to you, your drone is dead and its time to send it back or get a new one, take it from me I have gotten 2 replcments before I figured out the issue at hand! DJI please fix this problem, it completly bricking drones and I belive it is just a software bug in the DJI fly app. KEEP YOUR DRONE TRASSMISION ON AUTO AT ALL COSTS OR THAT COULD BE YOUR LAST FLIGHT!!!!!
