Bashy
Flight distance : 2354357 ft
Hipster1966 Posted at 5-20 12:43
I've just noticed all 3 of my mini 3 pro batteries have those hairline craps, only one catch on one battery isn't cracked. I've no idea how this has happened as I haven't used excessive force to insert and remove them, nor have they been dropped, banged or crashed. Having many RC helicopters in the past 20 years, I know through experience to handle li-po batteries with care. I've had my drone and batteries since March and cycled about 5 or 6 times each. Although they weren't recharged after flying. They were recharged because they discharged themselves if unused.y mini 3 has spent about 8 hours total in the air. Are my batteries covered by the warranty? Because this is down to using cheap inferior plastic for the hinges, that and no thought has gone into designing them. Considering the price of the mini 3 pro, or rather the replacement batteries, I would have expected the casing to be the last thing to go wrong with them. I do have DJI care refresh, but I shouldn't be made to use that for something thats a couple of months old and should be covered under the warranty.
Just normal removal usage is enough to cause this to happen, the problem being that there isn't anything underneath where the clasp compresses, its just empty space, this in turn leads to the clasp being pressed too far, which is compounded with cheaper materials.
Its sad to say that this isn't the 1st time DJI has used inferior quality plastic, just look at the Phantom 4 models, those batteries were renowned for forming cracks in them for no apparent reason and I'm not referring to the clasp either, the shell where the LED lights are, same goes for the legs (hairline cracks) and I think some on the main shell too but not I'm 100% certain on the latter. What makes it worse is that those batteries are £180 a pop, granted, the batteries are consumables but we are not talking fuel degradation here but the shell, this shouldn't happen.
At least DJI are aware of the Mini 3 batteries and this can be rectified by adding something behind the clasp to prevent it from being depressed too far. |
