120ccpm
Flight distance : 1396755 ft
If you know what you're doing, there is one thing you can try to resuscitate the batteries, and it's to open the housing in order to expose the 18650 cells, then apply direct voltage to each of them (UNDER SUPERVISION) for 5-10 minutes. Something like 5V should do it, limiting the current to 1A. This could (COULD) be enough to raise their voltage to a point where the built-in BMS doesn't refuse a charge anymore.
I have never done it with the Mini, but I used this method a few times to revive over-discharged LiPos that my RC charger would refuse to charge because their voltage was too low. Switch the charger to NiMh, let it pump a few mA into the battery to raise its voltage, then switch back to LiPo and charge as usual.
Note: there is a good possibility this method will not work with the Mini, and it's also possible that the cells are damaged beyond repair, but if you feel it's something you can SAFELY try, I'd give it a shot.
See this page for some photos of the Mini battery pack with its 18650 cells.
