Zoooom
Sean-bumble-bee Posted at 8-24 18:20
Does it matter whether the direction of travel is towards you or away from you?
It might be an idea to post a photo of the drone and the arm repair, I have bought a repaired Mavic Mini, with a glued up arm, (for parts) and the arm wasn't even correctly aligned.
https://dronesgator.com/when-to-replace-drone-propellers/
I notice that when I fling it around in sport mode, the sound is more harmonized. Also when it climbs, the sound is harmonized. But going forward direction, towards or away from me, it's likely to have a fizz, or lisp noise.
From pictures you can see an asymmetry in the prop angle, because I didn't want to force it too hard back into position, to close the crack, because the bottom might break. The JB Weld epoxy has hardened quite OK. I tested the Bondic UV glue, and it didn't look good enough.
It's not really important, just interesting to know if your drones had a lisp, when going forward. |
