New DJI Avata Firmware Released (08/25/2022)
12Next >
13947 48 2022-8-25
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2022.08.25
  • Aircraft Firmware: v01.01.0000
  • Goggles Firmware: v01.01.0000 (DJI Goggles 2)
  • v01.03.0000 (DJI FPV Goggles V2)
  • Motion Controller Firmware: v02.00.0400
  • Remote Controller Firmware: v02.00.0200
  • DJI Fly App iOS: v1.7.0
  • DJI Fly App Android: v1.7.0
What’s New
  • Added the ability to customize the camera's auto ISO limit in auto mode.
  • Added embedding gyroscope data in the recorded video on the aircraft. (EIS needs to turn off, and the camera FOV is set to Wide)
  • Added reminder when the aircraft is in low-power state.
  • Added orientation indicator when using the Head Tracking function with DJI Goggles 2.
  • Added manual channel mode for transmission and photo mode for camera when using DJI FPV Goggles V2.
  • Added orientation guidance for motion controller.
  • Optimized flight experience when using motion controller.
Note:
  • Restart the aircraft, remote controller, and goggles after the update is complete.
  • Note that the update may reset various flight parameters such as the RTH altitude and the maximum flight distance. Before updating, take note of your preferred settings and readjust them after the update.
  • If update fails restart the aircraft, remote controller, goggles, and DJI Fly or DJI Assistant 2 (Consumer Drones Series), and try again.
2022-8-25
Mini-G
Flight distance : 702005 ft
Nice one! Drone looks great!!
2022-8-25
Kosb
Ukraine
Hi! What about embedding gyroscope data in the recorded video on the aircraft on DJI FPV? When will it be available? The drone is awesome, but stabilization is really bad in comparison with the go pro and Reelsteady go and Gyro Flow stabilization. You guys will receive a ton of new sales for your DJI FPV drones if you give us an opportunity to use other apps for stabilization.
2022-8-25
Frontliner 2020
Philippines
thanks for the info and update...
2022-8-25
Fred Fred Fred
Flight distance : 4512966 ft
Thanks dji.
2022-8-26
Mat8861
Flight distance : 169400 ft
Got mine in order
2022-8-26
djiuser_W5TfettSSeNq
Flight distance : 254314 ft
Will the goggles 2 work on my DJI FPV and DJI camera in my Nazgûl? I am not sure I want to buy the new goggles with the Avata if they are not compatible with my other HD FPV drones.
2022-8-27
SoCalLucas
Flight distance : 50642090 ft
Awesome updates!
2022-8-28
dyanjp
Flight distance : 20974 ft
Can’t upgrade firmware from v01.01 tried the app plus dji assistant . This issue prevents me from binding the remote controller 2 , someone help !!!!
2022-8-29
KlooGee
Flight distance : 16783757 ft
djiuser_W5TfettSSeNq Posted at 8-27 00:00
No, the original Air Units and Vistas are not supported by the new Goggles 2.  Currently, the Goggles 2 only supports the Avata.
2022-8-29
djiuser_R9XCgbrvYRLX
Norway
Hello, yesterday I uploaded my dji fpv a drone to the new firmware. The Dji Goggles has now version of firmware v01.03.0000, remote controller has version v02.00.0200 and the drone  v01.01.0000. Now I cant connected my Goggles to the drone. Even when I downgrade version for all part DJI, the Goggles cannot establish a connection with the drone. Please, what cant I do?
2022-8-29
dyanjp
Theres a new firmware available for the drone and it doesn’t update for me in the app or the assistant it only shows V.01.01 someone help !
2022-8-29
fansdcab590a
Flight distance : 22618 ft
why am I getting "aircraft is in low-power state."?  All my three Avatar/Goggle/Motion Controller are fully charged.
2022-8-29
KlooGee
fansdcab590a Posted at 8-29 17:36
Because your drone is just sitting there not flying, so it's went into low power state to preserve your battery and limit the amount of heat it generates.  Its a good thing, not a bad thing.
2022-8-29
fansdcab590a
KlooGee Posted at 8-29 17:47
thank you KlooGee
2022-8-29
dyanjp
Is there a new update for the drone ? I am not able to connect my fpv controller 2 to the drone. My drone firmware version is the V01.01.000
2022-8-30
fans2914f156
Flight distance : 4990 ft
When will the DJI Virtual Flight app support Goggles 2?
2022-8-30
scoble08
Flight distance : 4327592 ft
fans2914f156 Posted at 8-30 01:43
The latest IOS version lists Googles 2 support.
2022-8-30
alextort44
Flight distance : 698143 ft
It does, I just used it a few minutes ago
2022-8-30
ScooterC5
Flight distance : 435052 ft
dyanjp Posted at 8-30 00:04
Yep, I got the same problem. I tried everything.
2022-8-30
rbrouwers123
Flight distance : 741788 ft
ScooterC5 Posted at 8-30 23:26
Same thing, can't pair with the RC 2. Super frustrating. Any help, please?
2022-8-31
Jumai
Flight distance : 376594 ft
Singapore
Hi dji,  talking about firmwares.
1. Is there a possibility for fpv v2 goggles to be in audience mode for goggles 2?
2. When will dji fpv be compatible with goggles 2?
Thanks.
2022-8-31
fans2914f156
alextort44 Posted at 8-30 13:27
Strange.. I just deleted the app on my iPhone, redownloaded to my phone and it’s still v1.3.2.. not sure what DJI’s process is for updating the App Store.
2022-9-1
Mat8861
go into goggles menu and select virtual flight. Follow instruction to connect goggles and motion controller and works.
2022-9-1
Mat8861
What i did: update motion controller firmware with dji assistant. Got on ipad DJI Fly app (my son wanted to try the virtual flight) connected and updated firmware goggles 2 it also asked to activate goggles and care refresh, then closed the app and shutdown googles, restarted fresh app, connected goggles and right after turned on avata, again firmware update,activation of avata and care refresh. You need to be patient, if you wait DJI Fly will ask for update and activation and also make sure you have everything charged. It took a while but i ended up with everything updated, started avata for a short flight until my dog started barking, then played Virtual flight (select virtual flight in goggles 2 menu, think it was in other, way down the left menu).
2022-9-1
Old Man Mike
Flight distance : 376050 ft
Been using the flight simulator app iPhone with goggles 2 and motion controller.  It works for a while but often the googles screen goes black while the iPhone and controller are still working with
the simulation.  It feels like a bug in the goggle 2 firmware.
2022-9-2
FPVTrendz
Flight distance : 1241020 ft
Thanks DJI
2022-9-2
fans00ba9f95
Me too, I could not get my android phone to find the DJI FLY app. But windows laptop got the Assistant 2 consumer drones downloaded and upgraded goggles and motion controller but not Avata.   VisionStarter3.exe-System Error
...because MSVCR100 was not found..  reinstalling did not fix
2022-9-3
fans86deb846
Hi can anyone please tell me why my Avatar is saying my drone in I low power state when everything is changed? Thank you
2022-9-3
Flymore91
Flight distance : 531483 ft
My avata Bricked after update. Flew before and now says esc error and will not fly. No it was not crash or hard landed. Battery was low and returned home and now i cant do anything. Ive reset the drone more than 15x and tried moving the props and i cant find any info online at all. Can someone point me in the right direction?
2022-9-4
djiuser_Evct1omRrBf8
Flight distance : 208510 ft
Russia
Hello! Can somebody explaine how rates EXP setting works in M mode? Why it sets from 0 to 1 in virtual fly app, and from 0to2 in actual Avata settings. And there is no graphic visualisation. I want to tune my rates on Avata but it seems not so easy for understanding for me.  Please help
2022-9-5
djiuser_O4fE6VyWEmM9
Mat8861 Posted at 9-1 13:26
Hi, apologies if this issue has been talked about to death!...But I have the same problem, however the DJI Assistant 2 (FPV Series) that I get off the DJI website doesn't support Mac IOS 11 or above, and all of my Macs are running on the latest IOS, the phone support from DJI was of no use as the poor person on the end of the phone just didn't have any idea.  Am I missing an updated link to download the new firmware??...
2022-9-6
djiuser_O4fE6VyWEmM9 Posted at 9-6 13:28
Apologies, I've found that downloading the Consumer version of the assistant has worked!  Only taken 10 hours to find the solution!  Happy flying!
2022-9-6
JAMh
Flight distance : 4754715 ft
djiuser_Evct1omRrBf8 Posted at 9-5 04:19
+1
Didnt´ find it anywhere
2022-9-6
birdie116
Malaysia
Hi, is anyone know why Avata will drift & crash by itself when flying indoor, I crashed twice the moment I'm going to landing, it will drift by itself when it reach the landing point around 1m.
2022-9-6
fans7a02a7e1
Flight distance : 149432 ft
I just got the Avata, but in the sd card which I have a 128 the screen only shows 22 size card. I reset it, tried a new card but the same. Googles read correctly. any help? thank you.
2022-9-7
djiuser_3E1HQWwIRtW9
India
I bought a new DJI AVATA. I switched off EIS and changed FOV to wide. But when uploading to gyroflow it does not detect any gyro data. The video codec is HEVC whereas the tutorials on YouTube show codec as H264.... what am I doing wrong?
2022-9-9
India
birdie116 Posted at 9-6 18:34
GPS does not work indoors and the avata is supposed to switch to using visual positioning sensors when Indoors. VPS is not very effective over reflective surfaces hence the drifting.
2022-9-9
djiuser_uVLIXzuGtlnQ
I just bought this, my first ever drone, it wont activate, flashing green red blue. I get no prompt to update firmware on pc or app, goggles and controller updated fine. please help!!!
2022-9-10
RichfromHowellNJ
Flight distance : 508255 ft
Is there a firmware update for the Avata Battery and the Goggles 2 Battery?  If so can this be done through DJI Assistant 2?
2022-9-10
12Next >
