JeffAlanMcClain
Flight distance : 2281043 ft
DJI Stephen Posted at 8-25 19:34
Hello there Jeff McClain. Good day and thank you for giving out these information. I will forward these information to the designated DJI Department for attention. Thank you.
BTW, a simple "Enable 2x frame rate shutter speed" in AUTO settings would be an awesome option. Basically, currently, I note that you will never see the shutter speed drop below the video frame rate (makes sense, since you can't run 60 fps with a 1/30 shutter speed). In this case, when enabled, it would clamp the minimum shutter speed to automatically be 2x the frame rate of video mode (which would automatically allow us to follow the 180 film rule) and should simply make the auto ISO increase, as needed to maintain correct exposure. |
