striperseeker
Flight distance : 10827 ft
DJI Wanda Posted at 8-25 19:50
Hello, there. Sorry for your inconvenience. DJI Air 2s will calculate the battery level required for returning to the Home Point based on the flight altitude from the takeoff point and distance with the Home Point in real time, and give a warning when the aircraft reaches the critical point. The RTH battery level cannot currently be set manually. For the settings you mentioned, may we know do you have a video?
What would you like a video of? I posted a picture showing NONE of the battery telemetry items are working. I understand the RTH time is based on distance, speed, and battery level and changes as you fly. But I remember being able to set the "Until Forced to Land" level as a percentage of battery life remaining. So for example, if I wanted to come home at 30% remaining charge, I could set that. Am I not correct? |
