Eveezy
Flight distance : 19170 ft
Beta5K Posted at 8-25 12:20
There may be a problem with the wheel itself. Have you tried using the slider on the screen to see if its the same?
So I tested using the touch screen and the wheel and it happens with both. It happens when tilting fast, slow whatever. For example when tilting while pushing the wheel at the highest speed it will studder at 15deg, 25deg, 45deg... etc.. its not exact I'm just giving an example. When tilting with a slow speed it would studder every 5 degrees of movement.
I also tested without my freewell DN filters just to make sure it wasn't caused by that.
It doesn't seem to happen at all other than using the tilt function, so its not really a major issue. The auto tilt for master shots etc.. work fine and smooth from what I can tell. Its only when manually tiliting the camera. |
