Sean-bumble-bee
Flight distance : 15997 ft
How can "That puny and totally unsatisfactory tiny screwdriver " strip screw threads? It would have to appy excessive torque to do that, which, by the quoted description it would be unable to do and besides you supply the torque.
That said I would try forcefully gripping the TOP of the propeller hub with pliers, applying sufficient force to crush the TOP, note TOP, of propeller's hub to the screw's head and whilst so crushing the hub twist the hub, probably anti clockwise.
Why do I stress the TOP of the propeller hub?
Because if I remember what I have seen correctly there is a spigot/boss/shoulder on the top of the motor that the propeller's hub fits over, if you crush the complete hub you would grip that shoulder and I do not know how that boss is attached to the motor, you might break it off the motor's top.
If you try this scrap the propeller. |
