nosnoop
Flight distance : 237953 ft
GLOBAL HAWK Posted at 8-28 23:55
It is a touchy subject. Again, it's not the device that's the concern but the wavelength being transmitted. SHF Super High Frequencies are documented as dangerous as far are close human exposure. In my work, we studied communications principles and exposure to RF radiation. Documented in our reference material was the fact that extended and close proximity exposure to SHF is quite harmful and should be avoided. Cellphones are not in the SHF, they are in the UHF spectrum. As the device is spaced further from the body the exposure is reduced hence my concern that its smack bang on your frontal lobe by literally 3-4cm. while using it. Thats pretty close for a device transmitting SHF radiation and I dont think it would transmit anything less than 1watt.
I don't want to be the tin foil hat user but would suggest potential buyers of this drone really look into it before purchasing. I was considering purchasing one but have pulled out now based on the concern of what the headset is transmitting. If the headset is a receiver then sold, if its actively transmitting, its a no deal. Just saying.
It will be similar to using your cell phone with WiFi calling (2.4 or 5Ghz). Haven't heard of any concern, and cell phones are placed at your ears and closer to your brain.
Anyways, the length of exposure is relatively short for most people. And if you are worried, you can always use the Goggle video output to an iPad. Not as immersive, but less radiation. |
