Buzzyone
Flight distance : 4647913 ft
You can use the Mavic 3 65W charger, there are also a number of PD chargers available from Amazon, use the USB-C socket as USB-A does not support PD. MacBook Pro chargers also work, if you have one.
Note that only the 4 battery hub will charge at 70W the supplied single battery adapter will only charge at 48W.
Using a mobile phone charger will bring disappointment!! |
