DJI Susan Posted at 10-15 04:03
Hi all, firmware requests above have been taken care of, please connect the drone and DJI Fly app and check for the update.
Hello DJI-Susan
I have the exactly same problem on my DJI Mini 3 Pro which reports Error Code 30064.
Please send the update to me as well.
DJI Susan Posted at 9-10 19:22
Hi all, we are sorry for the inconvenience caused. If the error existed after updating firmware or calibrating the vision system via DJI Assistant 2, our engineers are aware of the issue.
For Mini 3 Pro users who reported the issue on this thread, I sent the firmware to your DJI Forum account. Please check for the update.
I have [Mini3 Pro RC]
Can you please send me the beta software to resolve my code 30064 error?
my DJI fly account: kitichon.kunha@gmail.com
Thanks
djiuser_taJKhk7mRdff Posted at 10-16 08:28
Same error code 30064 after connecting to DJI assistant just to see what the app/ software does, now unable to take off. No update was carried out, just browsed the software.
Could I get the update too please?
I updated my firmware using the RC controller as I was told it was just the DJI Assistant 2 software which was breaking mini 3's but now I have the Unable to take off code 30064 error. Can someone post a link to the beta firmware please? I have just arrived on holiday and I am unable to take off while
DJI Susan Posted at 10-14 01:55
Hi all, firmware has been forwarded to the requests above. Please connect the drone and app and check for the update. Thank you.
Hello dji susan
Can you please send me the firmware update? I can‘t fly my new mini 3 pro anymore.
Regards
Hi, I just bought a new dji mini 3 pro and after connecting the dji assistant it has stopped flying please share me the firmware update on the fly app. My username is djiuser_CfpXyiiobn0s and my email id is dev.meena@live.com please do this, so I can fly this
they send the update to rc controller. you have to check on the rc controller if there was any update to be made, after you ask for DJI administrator to send to you.
Hi dji susan, can you please send me the FW upgrade. I can not fly my drone anymore (mini 3 pro with failure 30064)
Thanks Sam
I have the same problem. Code: 30064 Is there a solution? I tried everything but the problem remains
Hi. I have the 30064 issue also. How can I get the updated firmware please? (imn1969@outlook.com) Thanks, Ian
Same here, exchanged drone in warranty, new one started update, now is grounded.
Susan, please send the link in private message here, I don't make my mail address public.
Just in case it can help anyone with the firmware update.
- Send to DJI Susan the email address that you used to create your DJI account.
- Once the new firmware version is sent by DJI Susan, don't look for it in your email inbox, it won't be there.
- Just turn on the DJI RC, make sure that you're logged on with the same email account, and check for firmware updates as you usually do.
- The new version should appear. Install it and that's it!
DJI Susan Posted at 10-19 03:47
I didn't get the 30064 error, just the drone didn't start the motors.
But 310 firmware fixed everything. Thanks a lot, Susan!
LanceX Posted at 10-19 08:42
DJI Susan Posted at 10-20 06:14
Hi, i have just taken the drone to a DJI specialist and they couldn’t get it to connect to anything. The drone doesn’t enter pairing mode at all now. Can send any updated firware to my app? I have also emailed support saying this and that want a full refund but if this works I will withdraw the complaint about the drone.
Hello DJI-Susan
Please send the update to me as well. ribetto.emanuele@gmail.com
djiuser_mpcVPNOyw7Yp Posted at 10-20 21:22
Hi there, I am sorry to read about your case. May I know which controller you are using?
If you are using the RC N1, please help to confirm if the connection issue is with the controller and phone, or the controller and aircraft. If it is the controller and phone, please try to use a different connection cable, and make sure to use the latest DJI Fly app and check again.
If it is the issue with the controller and aircraft, please try to use the DJI Assistant 2 to update the firmware to the latest version, DJI Assistant 2 download link: https://www.dji.com/downloads/so ... sumer-drones-series
Then, please try to remove the SD card and relink the controller and aircraft, you can refer to this tutorial, starting at 6:54
If the issue persists, please provide a video of your case for us to confirm it further. Thank you.
