Mzp
alex_tseli Posted at 9-5 02:25
Thank you Labroides, DJI Paladin - I've started the warranty case with the retailer!
JBB*, thank you so much for the analysis. Yes, indeed, my hair turned gray in these 15 minutes. I had the same issue several days ago but it popped up seconds after the take off, so I assumed that if I could fly some 1000m it is all fine. When it started rotating I thought - that is it, it will drain the battery and fall from the sky as I won't be able to fly it back. However, I had some 30 minutes left to experiment and tried to use all my flying experience and managed to alternate between reverse flying and acceleration based on where the camera was pointing and flew back
Hi Alex / Folks,
I had this "drone dance" rotation issue clock wise or counter clockwise sorry can't recall exactly which one it was. It was due to gimbal , IMU and compass miscalibration. Once I re-calibrated gimbal, IMU and compass, the issue went away. I actually observed this issue while the drone was near me and I can describe the symptoms of this and how it happens. The gimbal would try to center itself, but due to miscallibaration of gimbal / IMU / compass, the gimbal would drift to either left or right, it would then hit its limit either left or right and the drone would do a jerky yaw move in the same direction where gimbal had drifted to, the gimbal would then get kind of centered after that jerky yaw move and would drift again in the same direction (left or right) , the drone would once more would do a jerky yaw move and it would continue forever. I noticed this happens when the drone is hovering, if you force the drone to move forward or backward, this does not seem to happen as much, but imho it's best to land asap and perform calibaration of all 3 - gimbal, iMU , compass on a flat surface. Hope this helps.
Thanks, Mike.
