JJB*
Flight distance : 12260774 ft
GeirB Posted at 2-2 00:42
So based on your comments it seems to me that it relies heavily on the vision system to keep its heading and that explains why it is so unstable. The above post from alex_markov clearly seem to indicate that hyperlapse does not produce satisfactory results in low light conditions.
Hi,
I wrote my post mainly to make clear that GPS is not used for heading stability.
Why there is een difference in day and night performance for heading stability, it is more complicated i guess and not 100% clear (for me).
Vision helps to maintain hover stability at daylight WHEN is in Vision range ofcourse.
Forward flight and hover heading stability at daylight, out of Vision range, is perfect.
No heading problems during a daylight Hyperlapse in or out of vision range.
But why at night heading performance is not as good as in daylight?Vision does not work in low light conditions, but during daylight out of range Vision does not work either.
So question remains a valid question, why that difference in performance.
I once taped the bottom vision sensors on a Mini3pro. Hover performance not as good as normal, my drone hovering at low height above the ground.
Nice idea to do some tests with my Mini4pro, hyperlapse in daylight (in and out vision range) and at night with taped/ no tape on the bottom vision sensors.
cheers
JJB
