LarShreve
Running P3P firmware update to most current as of August 4. Upgrade via the SD disk has been running in the P3P for over an hour. Started out with green and red lights blinking on camera display. For the last 30 minutes it has only been red blinking lights. Still the same tones as when it started. Only way to tell if there is an error is to turn off P3P, remove the card, and check on the PC for the TXT file status. Should I do this, or let it continue to run? Quick advice would be appreciated.
